Home » Eclipse Projects » Eclipse 4 » Styling editor
Styling editor [message #1735004] Tue, 14 June 2016 10:48 Go to next message
Hi!
I am trying to provide better colors for the highlighting in my editor when using the dark theme, using https://wiki.eclipse.org/Eclipse4/CSS/StylingOfPreferences as reference. I also defined this
    <extension point="org.eclipse.e4.ui.css.swt.theme">
      <stylesheet uri="dark_highlighting.css">
        <themeid refid="org.eclipse.e4.ui.css.theme.e4_dark">
        </themeid>
      </stylesheet>
However, the values don't seem to get used. How can I debug it?
BTW, the information about how to do this could be more visible IMHO, it took me a long while until finding a reference.
best regards,
Vlad
Re: Styling editor [message #1735011 is a reply to message #1735004] Tue, 14 June 2016 11:25 Go to previous messageGo to next message
Hmmm, I got it working somehow (saw even the 'overridenByCSS' property in the preference store), but after making some changes, it reverted to not working.
/Vlad
Re: Styling editor [message #1735021 is a reply to message #1735004] Tue, 14 June 2016 13:02 Go to previous message
Have you tried....
http://fxexperience.com/scenic-view/
Previous Topic:Java-Application can not be started - main method not found
Next Topic:Is there a way to use a fragment command in another fragment?
Current Time: Wed Nov 05 10:45:06 EST 2025
Powered by FUDForum. Page generated in 0.03628 seconds
