Home » Eclipse Projects » EclipseLink » EL-2.5.2 - Creating a single table takes 15 seconds.(Every table takes 15 seconds to create. Multiple retryQuery() calls.)
EL-2.5.2 - Creating a single table takes 15 seconds. [message #1734618] |
Thu, 09 June 2016 20:59  |
HI,
Ever since we updated from EL-2.4.2 to 2.5.2 it takes forever to create a single table. We are running EL in a Java-7 OSGi environment with Aries 1.1 and JPA 2.1 and commons-dbcp 1.4_3.
The problem appears to be that EL takes some time (...) to verify that the table doesn't already exist.
I am sure I am doing something wrong, but can't find anything about it. I mucked around with various property setting, but nothing I tried made a difference.
Does anyone have an idea what is going on here? As soon as I switch back to EL-2.4.2 and JPA 2.0.5 the system is lightning fast again.
Tested with mySQL 5.6.14 on W7 and 5.6.17 on OS X.
DB log of a single table creation and stack of 'slow' call attached.
Any suggestions are greatly appreciated.
Erwin
[EL Info]: connection: 2016-06-09 19:49:46.483--bundleresource://85.fwk471108564/_east.pu login successful
[EL Fine]: sql: 2016-06-09 19:49:46.524--Connection(1308068571)--SELECT ID FROM TABLE_ONE WHERE ID <> ID
[EL Fine]: sql: 2016-06-09 19:49:46.54--SELECT 1
[EL Fine]: sql: 2016-06-09 19:49:46.557--Connection(1166650879)--SELECT ID FROM TABLE_ONE WHERE ID <> ID
[EL Fine]: sql: 2016-06-09 19:49:46.558--SELECT 1
[EL Fine]: sql: 2016-06-09 19:49:51.58--Connection(2084829361)--SELECT ID FROM TABLE_ONE WHERE ID <> ID
[EL Fine]: sql: 2016-06-09 19:49:51.58--SELECT 1
[EL Fine]: sql: 2016-06-09 19:49:56.599--Connection(333624863)--SELECT ID FROM TABLE_ONE WHERE ID <> ID
[EL Fine]: sql: 2016-06-09 19:49:56.599--SELECT 1
[EL Fine]: sql: 2016-06-09 19:50:01.615--Connection(134797004)--SELECT ID FROM TABLE_ONE WHERE ID <> ID
[EL Fine]: sql: 2016-06-09 19:50:01.616--SELECT 1
[EL Finest]: query: 2016-06-09 19:50:01.617--Execute query DataModifyQuery(sql="CREATE TABLE TABLE_ONE (ID BIGINT NOT NULL, DELETED TINYINT(1) default 0, LASTMODIFIED DATETIME, TYPE VARCHAR(255) NOT NULL UNIQUE, VERSION BIGINT, PRIMARY KEY (ID))")
[EL Finest]: connection: 2016-06-09 19:50:01.618--Connection(1370835841)--Connection acquired from connection pool [read].
[EL Finest]: connection: 2016-06-09 19:50:01.618--reconnecting to external connection pool
[EL Fine]: sql: 2016-06-09 19:50:01.626--Connection(2051185449)--CREATE TABLE TABLE_ONE (ID BIGINT NOT NULL, DELETED TINYINT(1) default 0, LASTMODIFIED DATETIME, TYPE VARCHAR(255) NOT NULL UNIQUE, VERSION BIGINT, PRIMARY KEY (ID))
[EL Finest]: connection: 2016-06-09 19:50:01.646--Connection(1370835841)--Connection released to connection pool [read].
[EL Finest]: ddl: 2016-06-09 19:50:01.646--The table (TABLE_ONE) is created.
Daemon Thread [Thread-58] (Suspended)
owns: EntityManagerFactoryDelegate (id=119)
waited by: Daemon Thread [CM Configuration Updater (ManagedService Update: pid=[org.apache.aries.jpa.east.pu])] (Suspended)
Thread.sleep(long) line: not available [native method]
ServerSession(AbstractSession).retryQuery(DatabaseQuery, AbstractRecord, DatabaseException, int, AbstractSession) line: 1872
ServerSession(DatabaseSessionImpl).retryQuery(DatabaseQuery, AbstractRecord, DatabaseException, int, AbstractSession) line: 999
ServerSession(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord, int) line: 1840
ServerSession(AbstractSession).retryQuery(DatabaseQuery, AbstractRecord, DatabaseException, int, AbstractSession) line: 1874
ServerSession(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord) line: 1786
ServerSession(AbstractSession).executeQuery(DatabaseQuery) line: 1737
SchemaManager.checkTableExists(TableDefinition) line: 477
TableCreator.createTables(DatabaseSession, SchemaManager, boolean, boolean, boolean, boolean) line: 160
TableCreator.createTables(DatabaseSession, SchemaManager, boolean) line: 142
TableCreator.createTables(DatabaseSession, SchemaManager) line: 134
SchemaManager.createDefaultTables(boolean) line: 1032
EntityManagerFactoryProvider.generateDefaultTables(SchemaManager, EntityManagerSetupImpl$TableCreationType) line: 102
EntityManagerSetupImpl.writeDDLToDatabase(SchemaManager, EntityManagerSetupImpl$TableCreationType) line: 3999
EntityManagerSetupImpl.writeDDL(String, Map, DatabaseSessionImpl, ClassLoader) line: 3927
EntityManagerSetupImpl.writeDDL(Map, DatabaseSessionImpl, ClassLoader) line: 3827
EntityManagerSetupImpl.deploy(ClassLoader, Map) line: 728
EntityManagerFactoryDelegate.getAbstractSession() line: 204
EntityManagerFactoryDelegate.createEntityManagerImpl(Map, SynchronizationType) line: 304
EntityManagerFactoryImpl.createEntityManagerImpl(Map, SynchronizationType) line: 336
EntityManagerFactoryImpl.createEntityManager() line: 302
GenericRepositoryImpl<E>(AbstractRepository<E>).createEntityManager() line: 153
GenericRepositoryImpl<E>(AbstractRepository<E>).getAll() line: 336
SessionRepositoryImpl.getSystemInformation() line: 383
SystemInitializer.initialize() line: 30
Activator.init() line: 45
Activator.access$000(Activator) line: 22
Activator$1.run() line: 85
Thread.run() line: 745
Current Time: Sat Sep 13 23:15:44 EDT 2025
Powered by FUDForum. Page generated in 0.03619 seconds
