Home » Eclipse Projects » Sirius » Loading models: Loading referenced models of "representations.aird" hangs forever
Loading models: Loading referenced models of "representations.aird" hangs forever [message #1734385] Tue, 07 June 2016 15:04 Go to next message
Whenever I right click on my model.ecore file in Project Explorer I get a popup:
Loading models
It always hangs at 74%. I can cancel but it just goes to the "tray" at the bottom right of eclipse.
Here's what I've tried...
Disabled Model Nature, deleted representations.aird and then re-enabled Model Nature. This re-generates representations.aird but this process hangs at the very end. I have to kill eclipse and re-start. After this the representations.aird looks like:
<viewpoint:DAnalysis xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:viewpoint="http://www.eclipse.org/sirius/1.1.0" xmi:id="_8OBygCzbEeaIGai_XvvO4g" version="10.1.0.201509162000"/>
My ecore file is attached.
Would REALLY, REALLY appreciate some suggestions on this. It's driving me crazy.
Re: Loading models: Loading referenced models of &quot;representations.aird&quot; hangs fore [message #1734459 is a reply to message #1734385] Wed, 08 June 2016 09:41 Go to previous messageGo to next message
Hi Mike,
Which version of Sirius do you use ? On which version of Eclipse ? From
the version shown in your aird extract, it should be Sirius 3.1.x.
I tried with Sirius 3.1.5 on Mars.2 and Sirius 4.0 RC3 on Neon RC2 and I
was able to create a modeling project (and also an Ecore Modeling
Project) , activate the viewpoint provided by EcoreTools and play with
some diagrams on your model without any issue.
> Loading models
Maxime - Obeo
Re: Loading models: Loading referenced models of &quot;representations.aird&quot; hangs fore [message #1734499 is a reply to message #1734459] Wed, 08 June 2016 16:49 Go to previous messageGo to next message
I'm using Eclipse mars.2 (4.5.2) and Sirius 3.1.4.201602091241.
I've also checked the .metadata/.log file and there's no recent entries from when I try to load the ecore file.
Is there any way to turn on "trace" or "debug" to see what in the world Sirius is trying to load/access?
Re: Loading models: Loading referenced models of &amp;quot;representations.aird&amp;quot; ha [message #1735085 is a reply to message #1734499] Wed, 15 June 2016 08:45 Go to previous message
Hi Mike
You might launch a runtime in debug mode, try your scenario in the
runtime and suspend it when you get stuck at 74% to see where is the
potential deadlock.
Note that I rechecked with Sirius 3.1.4 on Mars.2 and Sirius 4.0.0RC3 on
Neon RC3 I do not have your issue.
Maxime - Obeo
Previous Topic:Hide standard menu and customise editor
Next Topic:New Arrangement after Deletion
Current Time: Wed Sep 24 07:48:06 EDT 2025
Powered by FUDForum. Page generated in 0.03554 seconds
