Home » Archived » Package Drone » Difficulty setting up an example p2 repository
| Difficulty setting up an example p2 repository [message #1734309] |
Tue, 07 June 2016 00:20   |
Eclipse User  |
I've followed the recipe text to create this sample channel (big thanks for providing the easy openshift setup) and I've uploaded my Tycho build to it. Eclipse successfully sees the update site, but it can't download any of the artifacts:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.modeling, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.source,3.0.0.201606070333
What could be the problem?
 Current Time: Mon Nov 03 18:46:56 EST 2025
 Powered by  FUDForum. Page generated in 0.07058 seconds
