Can't create workspace under neon [message #1734197] |
Mon, 06 June 2016 02:49  |
When I launching the eclipse neon after installation. I got an error:
Eclipse
An error has occurred. See the log file
C:\Users\Jamling\.p2\pool\configuration\1465180452260.log.
确定
The content of log is :
!SESSION 2016-06-06 10:59:03.958 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_45
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Framework arguments: -product org.eclipse.epp.package.android.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.android.product
!ENTRY org.eclipse.osgi 4 0 2016-06-06 10:59:04.315
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:78)
I found a solution on stackoverflow.com, added the following config in eclipse.ini
-Dosgi.bundles=org.eclipse.equinox.simpleconfigurator@1:start,org.eclipse.equinox.common@2:start,org.eclipse.equinox.ds@2:start,org.eclipse.equinox.event@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
And the eclipse launching successfully!
But when I create my first workspace, I got another error:
Eclipse
E:\eclipse\android-neon\workspace\.metadata\.log.
确定
!SESSION 2016-06-06 14:03:47.781 -----------------------------------------------
!ENTRY org.eclipse.m2e.logback.appender 2 0 2016-06-06 14:04:00.570
!MESSAGE Could not resolve module: org.eclipse.m2e.logback.appender [385]
Unresolved requirement: Fragment-Host: ch.qos.logback.classic
!ENTRY org.eclipse.osgi 4 0 2016-06-06 14:04:00.570
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:121)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:510)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:626)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!SESSION 2016-06-06 14:06:06.779 -----------------------------------------------
The env of my computer is : windows 7 64 bits OS, JDK 1.8.
Any one help me for this question? Thank you~
Re: Can't create workspace under neon [message #1734217 is a reply to message #1734197] |
Mon, 06 June 2016 05:46  |
Sorry, there was a bug in the RC3 installer. I've just created an RC3a
build to fix it. Until they update the link on the website
https://bugs.eclipse.org/bugs/show_bug.cgi?id=495523
you could get the fixed version from here:
https://hudson.eclipse.org/oomph/job/integration/lastSuccessfulBuild/artifact/products/
Or you could switch to Advance mode and use the button at the bottom of
the wizard to update your installer to the fixed version.
> Eclipse
> 确定 ---------------------------
> java.vendor=Oracle Corporation
> !STACK 1
> at
> eclipse.ini
> Eclipse
> !STACK 1
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
FUDForum. Page generated in 0.04960 seconds
