IllegalValueException when extending EssentialOCL [message #1733934] |
Thu, 02 June 2016 10:21 |
Florian König Messages: 30 Registered: June 2014 |
Member |
I want to extend EssentialOCL to use its expressions in my Xtext grammar, but I cannot figure out where this error comes from.
My Xtext grammar (a simple test):
grammar org.xtext.example.extendingOCL.EOCL with org.eclipse.ocl.xtext.essentialocl.EssentialOCL
generate eOCL "http://www.xtext.org/example/extendingOCL/EOCL"
import "http://www.eclipse.org/ocl/2015/EssentialOCLCS" as essentialocl
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Greeting:
'Hello' model=Model;
My workflow:
module org.xtext.example.extendingOCL.GenerateEOCL
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.example.extendingOCL"
rootPath = rootPath
eclipsePlugin = {
enabled = true
createEclipseMetaData = true
code = {
encoding = "windows-1252"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "org.xtext.example.extendingOCL.EOCL"
fileExtensions = "eocl"
referencedResource = "platform:/resource/org.eclipse.ocl.xtext.essentialocl/model/EssentialOCLCS.genmodel"
referencedResource = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
parserGenerator = {
options = {
backtrack = true // because OCL is no LL(*)-grammar
Whenever I try to generate the grammar, I get this IllegalValueException. It seems like I am missing something in the mwe2 workflow, but I don't know what it is. I added my projects as a zip archive to this post.
Can anybody help?
Stacktrace:
0 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
17 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
156 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project org.antlr.runtime at 'archive:file:/C:/eclipse-OCL/plugins/org.antlr.runtime_3.2.0.v201101311130.jar!/' and using 'archive:file:/C:/eclipse-OCL/plugins/org.antlr.runtime_4.3.0.v201502022030.jar!/' instead.
178 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.xtext.example.extendingOCL at 'file:/C:/Users/Florian/workspace/ScenarioTools-OCL/org.xtext.example.extendingOCL/'
179 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.xtext.example.extendingOCL.ide at 'file:/C:/Users/Florian/workspace/ScenarioTools-OCL/org.xtext.example.extendingOCL.ide/'
180 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.xtext.example.extendingOCL.ui at 'file:/C:/Users/Florian/workspace/ScenarioTools-OCL/org.xtext.example.extendingOCL.ui/'
192 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
768 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
774 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
786 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
786 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
949 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/ocl/2015/EssentialOCLCS' from 'platform:/resource/org.eclipse.ocl.xtext.essentialocl/model/EssentialOCLCS.genmodel'
949 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/ocl/2015/BaseCS' from 'platform:/resource/org.eclipse.ocl.xtext.base/model/BaseCS.genmodel'
949 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/ocl/2015/Pivot' from 'platform:/resource/org.eclipse.ocl.pivot/model/Pivot.genmodel'
950 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/emf/2002/Ecore' from 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel'
1907 [main] INFO text.xtext.generator.XtextGenerator - Generating org.xtext.example.extendingOCL.EOCL
6963 [main] INFO nerator.ecore.EMFGeneratorFragment2 - Generating EMF model code
7030 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.xtext.org/example/extendingOCL/EOCL' from 'platform:/resource/org.xtext.example.extendingOCL/model/generated/EOCL.genmodel'
18939 [main] INFO text.xtext.generator.XtextGenerator - Generating common infrastructure
19866 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow org.xtext.example.extendingOCL.GenerateEOCL:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: XtextGenerator)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.emf.ecore.impl.DynamicEObjectImpl@29f58b44 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@6ef7623 (name: EReference) (instanceClassName: null) (abstract: false, interface: false))' is not legal. (platform:/resource/org.xtext.example.extendingOCL/model/generated/EOCL.genmodel, 10, 132)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.xtext.generator.util.GenModelUtil2.getGenModelResource(GenModelUtil2.java:201)
at org.eclipse.xtext.xtext.generator.util.GenModelUtil2.getGenPackage(GenModelUtil2.java:119)
at org.eclipse.xtext.xtext.generator.model.TypeReference.getQualifiedName(TypeReference.java:236)
at org.eclipse.xtext.xtext.generator.model.TypeReference.<init>(TypeReference.java:149)
at org.eclipse.xtext.xtext.generator.model.JavaFileAccess$JavaTypeAwareStringConcatenation.getStringRepresentation(JavaFileAccess.java:73)
at org.eclipse.xtend2.lib.StringConcatenation.append(StringConcatenation.java:177)
at org.eclipse.xtend2.lib.StringConcatenation.append(StringConcatenation.java:148)
at org.eclipse.xtend2.lib.StringConcatenation$SimpleTarget.append(StringConcatenation.java:523)
at org.eclipse.xtend2.lib.StringConcatenation$IndentedTarget.append(StringConcatenation.java:571)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2$15.appendTo(SerializerFragment2.java:752)
at org.eclipse.xtend2.lib.StringConcatenation.append(StringConcatenation.java:175)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2$7.appendTo(SerializerFragment2.java:584)
at org.eclipse.xtend2.lib.StringConcatenation.append(StringConcatenation.java:129)
at org.eclipse.xtend2.lib.StringConcatenation.append(StringConcatenation.java:108)
at org.eclipse.xtext.xtext.generator.model.JavaFileAccess.setContent(JavaFileAccess.java:215)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2.generateAbstractSemanticSequencer(SerializerFragment2.java:621)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2.generate(SerializerFragment2.java:244)
at org.eclipse.xtext.xtext.generator.CompositeGeneratorFragment2.generate(CompositeGeneratorFragment2.java:48)
at org.eclipse.xtext.xtext.generator.XtextGenerator.invokeInternal(XtextGenerator.java:202)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.emf.ecore.impl.DynamicEObjectImpl@29f58b44 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@6ef7623 (name: EReference) (instanceClassName: null) (abstract: false, interface: false))' is not legal. (platform:/resource/org.xtext.example.extendingOCL/model/generated/EOCL.genmodel, 10, 132)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2697)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2682)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2141)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XMLHandler.java:2794)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2755)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2195)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2071)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:151)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1876)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:82)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 32 more
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to org.eclipse.emf.ecore.EStructuralFeature
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenFeatureImpl.eSet(GenFeatureImpl.java:762)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2692)
... 65 more
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to org.eclipse.emf.ecore.EPackage
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.getEcorePackage(GenPackageImpl.java:1235)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.reconcile(GenPackageImpl.java:4119)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.reconcile(GenModelImpl.java:9099)
at org.eclipse.xtext.xtext.generator.util.GenModelUtil2.getGenModelResource(GenModelUtil2.java:211)
at org.eclipse.xtext.xtext.generator.util.GenModelUtil2.getGenClassifier(GenModelUtil2.java:45)
at org.eclipse.xtext.xtext.generator.util.GenModelUtil2.getJavaTypeName(GenModelUtil2.java:262)
at org.eclipse.xtext.xtext.generator.junit.Junit4Fragment2.generateExampleRuntimeTest(Junit4Fragment2.java:164)
at org.eclipse.xtext.xtext.generator.junit.Junit4Fragment2.generate(Junit4Fragment2.java:131)
java.lang.RuntimeException: Problems running workflow org.xtext.example.extendingOCL.GenerateEOCL:
... 32 more
... 65 more
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
Caused by: java.lang.RuntimeException:
... 32 more
... 65 more
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.handleIssues(Mwe2Bridge.java:56)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:48)
... 4 more
FUDForum. Page generated in 0.04622 seconds
