Change default encoding without opening Elipse [message #1733725] |
Tue, 31 May 2016 08:58 |
Wan White Wolf Messages: 2 Registered: May 2016 |
Hello everyone
I wanted to switch the default encoding to support Japanese characters. So I was trying each available encoding and see if I can get something out of it. Unfortunately, once I set the UTF-16, my Eclipse crashed. Each time I open Eclipse it crashes. Someone submitted a bug concerning this issue but I didn't see any followup.
Does anyone know how I can change the default encoding without opening Eclipse (since it crashes before I can reach the settings). I looked into the eclipse folder, but didn't find any way to manually change this.
Thank you.
WWW
[Updated on: Wed, 01 June 2016 13:36] Report message to a moderator
Re: Change default encoding without opening Elipse [message #1733870 is a reply to message #1733853] |
Wed, 01 June 2016 15:21 |
Ed Merks Messages: 33142 Registered: July 2009 |
What happens with an empty new workspace? Of course just changing the
default encoding could make all your text files invalid if they're not
encoded with that encoding.
On 01.06.2016 15:34, Wan White Wolf wrote:
> Nitin Dahyabhai wrote on Tue, 31 May 2016 17:41
>> How did you set it? Does your JRE support that encoding?
> Hello Nitin,
> For setting the encoding , I did something like:
> Window -> Preferences -> General -> Workspace -> Text file encoding
> Then a scoolbar popped up. Several encoding options were available,
> when I selected UTF-16 (I believe) , it crashed.
Ed Merks
FUDForum. Page generated in 0.05103 seconds
