TemplateProposal does not get inserted any more [message #1733535] |
Sun, 29 May 2016 22:05 |
I have DSL and use TemplateProposals to edit my DSL file. Now I changed the syntax of the DSL and afterward one TemplateProposal does not get inserted any more.
I cleaned the project and regenerated the xtext dependend classes by executing the corresponding workflow.
Which method I have to debug, to inspect why the template does not get inserted any more ?
Or are there other reasons I can check before debugging ?
Re: TemplateProposal does not get inserted any more [message #1733540 is a reply to message #1733535] |
Mon, 30 May 2016 03:43 |
you mean by "inserted" that it i proposed and when you select it nothing happens?
or is it not proposed at all?
if you change the grammar the context ids inside the templates may have changed.
you may use
org.eclipse.xtext.ui.editor.templates.DefaultTemplateProposalProvider.createTemplates(TemplateContext, ContentAssistContext, ITemplateAcceptor)
as starting point to debug.
or
TemplateProposal.apply
Twitter : @chrdietrich
Re: TemplateProposal does not get inserted any more [message #1733624 is a reply to message #1733540] |
Mon, 30 May 2016 13:43 |
Christian Dietrich wrote on Sun, 29 May 2016 23:43you mean by "inserted" that it i proposed and when you select it nothing happens?
Yes it is proposed but not inserted
you may use
or
Thank you for the hint, I found the mistake. It was an wrong coded "ß" in a template variable.
FUDForum. Page generated in 0.02298 seconds
