Home » Modeling » UML2 » How to manipulate UML Class Diagram Elements
How to manipulate UML Class Diagram Elements [message #1733029] |
Mon, 23 May 2016 13:04 |
Hi all,
I want to modify an UML Class Diagram by java code, for this purpose first, I load an UML model by below java code, But I don't know how to change elements of "UMLModel" in run method. (for example change name of "Person" class to "Human").
package example ;
import java.io.File;
import java.util.ArrayList;
import java.util.Collection;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.epsilon.emc.emf.InMemoryEmfModel;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.resources.util.UMLResourcesUtil;
public class MinimalExample {
public static void main(String[] args) throws Exception {
new MinimalExample().run();
public void run() throws Exception {
InMemoryEmfModel Model = getUmlModel("UMLModel", new File("src/models/Dev1.uml"));
public InMemoryEmfModel getUmlModel(String name, File file) throws Exception {
ResourceSet set = new ResourceSetImpl();
UMLResourcesUtil.init(set);
set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
set.getResourceFactoryRegistry().getExtensionToFactoryMap().
put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Resource r = set.getResource(URI.createFileURI(file.getAbsolutePath()), true);
r.load(null);
Collection<EPackage> ePackages = new ArrayList<EPackage>();
for (Object ePackage : set.getPackageRegistry().values()) {
ePackages.add((EPackage) ePackage);
return new InMemoryEmfModel(name, r, ePackages);
Can one help me?
I used emc and eol epsilon plugin for this project and attached a minimal example to this post.
Mohammadreza
Attachment: Minimal.rar
(Size: 5.22KB, Downloaded 215 times)
Re: How to manipulate UML Class Diagram Elements [message #1733142 is a reply to message #1733029] |
Tue, 24 May 2016 17:56 |
Mohammadreza,
I don't know what emc and eol are.
But the UML2 project provides an API that has all of the tools
necessary for manipulation of UML models, including modification of all
of the attributes and associations defined by the language
specification. For example, to change the name of a class from
"Person" to "Human", you would simply use the
org.eclipse.uml2.uml.NamedElement::setName method, as the Java class
implementing the UML Class metaclass conforms to the NamedElement Java
interface.
HTH,
Christian
On 2016-05-23 13:04:35 +0000, Mohammadreza Sharbaf said:
> Hi all,
> package example ;
> Resource r =
> r.load(null);
> Can one help me?
> Best regards,
> Mohammadreza
> <image>
Re: How to manipulate UML Class Diagram Elements [message #1733148 is a reply to message #1733142] |
Tue, 24 May 2016 18:19 |
Ed Willink Messages: 7655 Registered: July 2009 |
It's best to ask Epsilon questions on the Epsilon newsgroup.
Ed Willink
On 24/05/2016 18:56, Christian W. Damus wrote:
> Mohammadreza,
> all of the attributes and associations defined by the language
> interface.
> HTH,
> Christian
>> Hi all,
>> package example ;
>> throws Exception {
>> Resource r =
>> r.load(null);
>> Can one help me?
>> Best regards,
>> Mohammadreza
>> <image>
Current Time: Sat Apr 27 03:11:23 GMT 2024
Powered by FUDForum. Page generated in 0.03014 seconds
