Home » Eclipse Projects » EclipseLink » Multitenancy and History Policy not working together
Multitenancy and History Policy not working together [message #1732677] Thu, 19 May 2016 02:33
I tried to get the History Policy and multi tenancy configured for some tables using EclipseLInk Version 2.5.2.
I get the Multi tenancy alone working using @Multitenant and @TenantTable Discriminator.
I get the History Policy working alone using @Customizer.
Both together are not working and deliver a null Point exception because the field attributeField in the class InstanceVariableAtributeAccessor is null (which is not when I disable the Multi tenancy).
Is this Problem known?
Is EclipseLInk developped to allow both Options to be used on the same table or These otpions are exclusive?
Is there any example of Project using These 2 Options on one table?
Thanks for any Information or tip.
Laurent
Previous Topic:LIMIT query not framed correctly when using CompositePU
Next Topic:JPA 2.1 @Converter bug?
Current Time: Thu Sep 25 20:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.36080 seconds
