Re: Sleeping workspace [message #1732672 is a reply to message #1732647] |
Thu, 19 May 2016 05:23 |
Ed Merks Messages: 33142 Registered: July 2009 |
José,
As the message suggest, this happens if the workspace is building and
you try to modify the workspace during that process. Eventually the
build should complete and your user operation can continue. Is that not
the case for you? I.e., does it hang/deadlock in this state forever?
You can monitor the Progress view to see what's currently building.
Perhaps the Vaadin framework installs a builder that's ill behaved...
On 18.05.2016 14:31, José Antonio Delgado Trujillo wrote:
> i'm working with Mars Eclipse in a web project using the framework
> vaadin.
> When i tried to build the project i find eclipse blocked.
> The reason is ...
> "The user operation is waiting for "Building workspace" to complete.
> What does it happen? and why?
> Any possible solution?
Ed Merks
FUDForum. Page generated in 0.07784 seconds
