Home » Newcomers » Newcomers » Exlipse as a new language editor(I made some xml base language.I need to create a eclipse version for that.)
icon10.gif  Exlipse as a new language editor [message #1731922] Wed, 11 May 2016 01:17 Go to next message
I build a xml tag base language.Now I used sublime-text as a editor. This language no need to compile at the moment.It's done by another tool.
Basically I need code hint, code suggestion and auto complete the tags.
To do this task IDE must have file compare with tag and it's attributes.
I need do something similar to below as a first step.
Example :
#data.xml
<Data>
<DataField id="Username" dbcolumnName="tbluser.username">
<DataField id="Password" dbcolumnName="tbluser.password">
<DataField id="PasswordTip" dbcolumnName="tbluser.passwordtip">
</Data>
#FormUser.xml
<Form dataFiled ="data.xml"> <!-- this mean refer the data.xml and get id fields -->
<Field id="dataFiled.Username" />
<Field id="dataFiled.Password" />
<Field id="dataFiled.PasswordTip" />
</Form>
Re: Exlipse as a new language editor [message #1732011 is a reply to message #1731922] Wed, 11 May 2016 12:35 Go to previous messageGo to next message
Do you have a DTD for your XML?
Re: Exlipse as a new language editor [message #1732027 is a reply to message #1732011] Thu, 12 May 2016 01:26 Go to previous messageGo to next message
No.It's not define.
Re: Exlipse as a new language editor [message #1732036 is a reply to message #1732027] Thu, 12 May 2016 03:36 Go to previous message
OK.
You could then start at e.g. <http://www.w3schools.com/xml/xml_dtd_intro.asp>.
The Eclipse XML editor can do most of what you're asking for, if you provide it with a suitable DTD.
Previous Topic:Cannot find source code for Neon package
Next Topic:outline dialog not visible
Current Time: Wed Nov 05 12:28:24 EST 2025
Powered by FUDForum. Page generated in 0.09021 seconds
