Home » Language IDEs » Java Development Tools (JDT) » unmappable character for encoding UTF8 when compiling by Eclipse
unmappable character for encoding UTF8 when compiling by Eclipse [message #1730765] Thu, 28 April 2016 07:04
Using DOS shell on Windows compile successfully, which show that my build.xml file, Ant, JDK setup and the Java source files are ok.
However, using Eclipse to compile (running the build.xml file as an Ant task) fail with the
"unmappable character for encoding UTF8" message.
The build.xml file originally has
<javac srcdir="${src}" destdir="${classes}" deprecation="on" debug="yes" target="1.6" source="1.6">
Then I change the build.xml by adding "encoding" to javac.
i.e.
The build.xml file has changed to
<javac srcdir="${src}" destdir="${classes}" deprecation="on" debug="yes" target="1.6" source="1.6" encoding="utf8">
which Eclipse compile with the same error.
However, change the build.xml with encoding="cp1252":
<javac srcdir="${src}" destdir="${classes}" deprecation="on" debug="yes" target="1.6" source="1.6" encoding="cp1252">
which Eclipse compile without any error.
I had already added "UTF-8" to the Default Encoding box in Eclipse for the following:
Window > Preferences > General > Content Types > Text
Window > Preferences > General > Workspace, set "Text file encoding" to "Other : UTF-8".
Please help.
Thanks.
Previous Topic:Run java program with unicode arguments in eclipse
Next Topic:Developing a AST parser plugin, but starting as a standalone first
Current Time: Wed Nov 05 14:38:11 EST 2025
Powered by FUDForum. Page generated in 0.03073 seconds
