Home » Eclipse Projects » EclipseLink » Uni-directional OneToMany problems with JPA2.0 -> JPA2.1 migration(Insert and Delete problems with not nullable fields in Eclipselink)
Re: Uni-directional OneToMany problems with JPA2.0 -> JPA2.1 migration [message #1730549 is a reply to message #1730533] |
Tue, 26 April 2016 15:36 |
Thomas Kernstock Messages: 29 Registered: July 2009 Location: Vienna |
Hi Chris,
thank you for your answer. I will try the suggested changes.
I made further investigations with these issues, debugging the SQL statements generated on the Glasfish 3.1.1. server that's working.
Adding a new child entity has the following SQL statements which are the same as on the new server ->
[#|2016-04-26T17:22:55.613+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=25;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:22:55.613--ClientSession(1645443748)--Connection(1826150217)--Thread(Thread[http-thread-pool-80(2),5,grizzly-kernel])--INSERT INTO bewerberedv (Bearbeitet, Bereich, Bewertung, Dauer, Kenntnis, Version, ZuletztVerwendet) VALUES (?, ?, ?, ?, ?, ?, ?)
bind => [true, 6, 1, null, 377, 2016-04-26 17:24:08.0, null]
[#|2016-04-26T17:22:55.628+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=25;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:22:55.628--ClientSession(1645443748)--Connection(1826150217)--Thread(Thread[http-thread-pool-80(2),5,grizzly-kernel])--SELECT LAST_INSERT_ID()
[#|2016-04-26T17:22:55.644+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=25;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:22:55.644--ClientSession(1645443748)--Connection(1826150217)--Thread(Thread[http-thread-pool-80(2),5,grizzly-kernel])--UPDATE bewerberedv SET BewerberID = ? WHERE (ID = ?)
bind => [2575, 1223970]
The difference is, that on the new server the INSERT fails because the field "BewerberID" can't be NULL. Somehow the check in the database seems to be different.
The same is for the DELETE which has following output ->
[#|2016-04-26T17:13:39.363+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=31;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:13:39.363--ClientSession(792940001)--Connection(1806567172)--Thread(Thread[http-thread-pool-80(4),5,grizzly-kernel])--UPDATE bewerbungen SET BewerberID = ?, PositionID = ?, InseratID = ?, Version = ? WHERE ((ID = ?) AND (Version = ?))
bind => [null, null, null, 2016-04-26 17:14:52.0, 1304157, 2016-04-26 17:14:25.0]
[#|2016-04-26T17:13:39.363+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=31;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:13:39.363--ClientSession(792940001)--Connection(1806567172)--Thread(Thread[http-thread-pool-80(4),5,grizzly-kernel])--UPDATE inserateanz SET AnzahlBew = ?, AnzOffeneBewerbung = ?, AnzNeueBewerbung = ? WHERE (ID = ?)
bind => [0, 0, 0, 61277]
[#|2016-04-26T17:13:39.363+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=31;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:13:39.363--ClientSession(792940001)--Connection(1806567172)--Thread(Thread[http-thread-pool-80(4),5,grizzly-kernel])--UPDATE positionenanz SET AnzahlBew = ?, AnzOffeneBewerbung = ?, AnzNeueBewerbung = ? WHERE (ID = ?)
bind => [0, 0, 0, 44726]
[#|2016-04-26T17:13:39.363+0200|INFO|glassfish3.1.1|javax.enterprise.system.std.com.sun.enterprise.server.logging|_ThreadID=31;_ThreadName=Thread-2;|[EL Fine]: 2016-04-26 17:13:39.363--ClientSession(792940001)--Connection(1806567172)--Thread(Thread[http-thread-pool-80(4),5,grizzly-kernel])--DELETE FROM bewerbungen WHERE ((ID = ?) AND (Version = ?))
bind => [1304157, 2016-04-26 17:14:52.0]
Thats interesting because on the new server I have the same update statement "UPDATE bewerbungen SET BewerberID = ?, ...." but there it fails immediately with the null constraint!
[Updated on: Tue, 26 April 2016 16:34] Report message to a moderator
Current Time: Fri Apr 26 15:10:04 GMT 2024
Powered by FUDForum. Page generated in 0.03861 seconds
