Home » Eclipse Projects » Oomph » Setup task execution on re-start
Setup task execution on re-start [message #1730320] Sun, 24 April 2016 12:28 Go to next message
I usually have the preference for skipping automatic task execution at
start-up turned off because otherwise I would download an enormous
Papyrus build into my PDE Target every time I re-start my workbench.
However, there are times when the workbench is re-started by Oomph.
When I specifically run the setup from the menu and that includes an
update of my installation (via p2 tasks), Oomph will automatically
re-start the workbench to finalize that update with the expectation
that then it will continue with the rest of the tasks prescribed by the
setup model. But because I have the automatic task execution skipping
preference set, that doesn't happen. I have to manually trigger the
setup again, deselect the p2 tasks that were already done, and then
complete the wizard.
I think it would make sense that the preference be ignored on the
occasion of this particular Oomph-initiated re-start. Is there already
an option to do this? Or perhaps the Oomph team would be interested in
receiving a contribution that makes it happen?
Christian
Re: Setup task execution on re-start [message #1730340 is a reply to message #1730320] Mon, 25 April 2016 04:11 Go to previous messageGo to next message
Christian,
Comments below.
On 24.04.2016 18:28, Christian W. Damus wrote:
The PDE task shouldn't return isNeeded true on startup trigger if the
the target is already active and resolved.
> the setup model. But because I have the automatic task execution
> skipping preference set, that doesn't happen. I have to manually
> trigger the setup again, deselect the p2 tasks that were already done,
> and then complete the wizard.
I see. Certainly if you're restarting and there are outstanding tasks
to execute, we should consider that. Also the first time you launch,
but I think that works okay because the preference isn't applied to the
workspace until during that first time...
> already an option to do this? Or perhaps the Oomph team would be
> interested in receiving a contribution that makes it happen?
Yes, it seems reasonable. We do store the outstanding tasks in a file,
so if that file is not empty, we could assume that the user want's those
automatically performed.
> Christian
Re: Setup task execution on re-start [message #1730367 is a reply to message #1730340] Mon, 25 April 2016 06:32 Go to previous messageGo to next message
I've changed this in https://bugs.eclipse.org/bugs/show_bug.cgi?id=492349
On 25.04.2016 10:11, Ed Merks wrote:
> Christian,
> Comments below.
>> at start-up turned off because otherwise I would download an enormous
>> done, and then complete the wizard.
> the workspace until during that first time...
> file, so if that file is not empty, we could assume that the user
> want's those automatically performed.
>> Thanks,
>> Christian
Re: Setup task execution on re-start [message #1730396 is a reply to message #1730367] Mon, 25 April 2016 08:41 Go to previous message
Wow! Thanks, Ed.
cW
>> Christian,
>> Comments below.
>>> Hi,
>>> Thanks,
>>> Christian
Previous Topic:How to achieve 'inheritance' of products ?
Next Topic:Simple mode installer broken with Neon
Current Time: Sun Sep 21 07:47:30 EDT 2025
Powered by FUDForum. Page generated in 0.03235 seconds
