Home » Eclipse Projects » GEF » FXHoverTool should only look at nodes contained within the IViewer
FXHoverTool should only look at nodes contained within the IViewer [message #1729038] Sat, 09 April 2016 19:12 Go to next message
I am working through Frank Benoit's tutorial [1], converting from a pure JavaFX application into an e4 RCP application that uses JavaFX as the renderer. This is working pretty well - essentially just change the target to replace the Eclipse platform location with the E(fx)clipse Target Platform. You can then just create your MVC.FX module in an RCP part and off you go.
One irritation is the FXHoverTool is constantly spitting out exceptions because it is trying to find policies for Nodes that are not part of the IViewer. In my case, the FXViewer's canvas is the child of an HBox, so that I can have a palette component on the left of the part. It's the event handler created in FXHoverTool.createHoverFilter() that is barfing - it even has a comment:
// FIXME: For some events, "The given target Node is not
// contained within an IViewer."
It would be really nice if this were fixed quite soon!
[1] http://fbenoit.blogspot.co.nz/2015/11/gef4-tutorial-part1.html
Re: FXHoverTool should only look at nodes contained within the IViewer [message #1729043 is a reply to message #1729038] Sun, 10 April 2016 02:00 Go to previous messageGo to next message
Can you please raise a bug?
Re: FXHoverTool should only look at nodes contained within the IViewer [message #1729076 is a reply to message #1729043] Sun, 10 April 2016 19:30 Go to previous messageGo to next message
Raised bug #491401
Re: FXHoverTool should only look at nodes contained within the IViewer [message #1729459 is a reply to message #1729076] Thu, 14 April 2016 06:03 Go to previous message
Hi Colin,
I added a null check within FXTypeTool and resolved the bug. If you find another related problem, feel free to reopen the ticket.
Matthias
Previous Topic:Registering children of a group
Next Topic:automatic graph creation from xml using eclipse gef
Current Time: Sat Nov 08 05:43:58 EST 2025
Powered by FUDForum. Page generated in 0.05732 seconds
