Home » Modeling » TMF (Xtext) » Ambiguous binary operator in a PLSQL grammar(conflict between the multiplication operator (*) and the wildcard '*' in SQL SELECT sentence)
icon5.gif  Ambiguous binary operator in a PLSQL grammar [message #1728777] Thu, 07 April 2016 04:59 Go to next message
I'm developing a grammar for Oracle PLSQL and I found a conflict between the multiplication operator (*, asterisk) and the wildcard '*' in SELECT * FROM.
QueryBlockFoo
: selectSentence='SELECT' '*' 'FROM' ';'
Multiplication returns Expression
: UnitaryOperator (({Operation.left=current} op='*') right=UnitaryOperator)*
When I test the grammar, the SELECT * FROM sentence works in a correct way, while the arithmetic operation ( var_a := 5*4; ) produces the error "mismatched input '*' expecting ';'
How can I resolve that?
Thanks in advance,
Cristo Rodriguez
Re: Ambiguous binary operator in a PLSQL grammar [message #1728832 is a reply to message #1728777] Thu, 07 April 2016 13:16 Go to previous messageGo to next message
can you share a complete grammar that reproduces the problem?
maybe SELECT * FROM; could be a VarableRef(Select) * VariableRef(FROM); in your grammar
Re: Ambiguous binary operator in a PLSQL grammar [message #1729465 is a reply to message #1728832] Thu, 14 April 2016 06:27 Go to previous message
Thank you Christian,
I made a mistake because I defined '*' as a "terminal" rule.
When I remove the clause terminal, the grammar work well.
Cristo
Previous Topic:Default Scope Shadowing
Next Topic:how to link new xpand project to existing xtext model
Current Time: Sat Nov 08 22:06:05 EST 2025
Powered by FUDForum. Page generated in 0.02942 seconds
