Re: Eclipse Mars SSL connection issue : javax.net.ssl.SSLHandshakeException: sun.security.validator. [message #1728692 is a reply to message #1728669] |
Wed, 06 April 2016 13:21 |
Tauno Voipio Messages: 742 Registered: August 2014 |
Awanthika Senarath wrote on Wed, 06 April 2016 14:36Thanks for the reply,
There are not enough details, but an educated guess is that you're attempting to connect to a HTTPS (SSL/HTTP) server, and the new installation does not have required certificates or root certificate path properly installed.
Yes , your guess is correct.
The problem is the same code works perfectly in Eclipse Luna, but fails in Eclipse Mars. Do we need to do anything more than what we do in Luna to have " required certificates or root certificate path properly installed" ?
Again, there are not enough details, but firstly, you should learn about SSL setup.
Some of the questions are:
- Is the server in a publicly-known certifying chain?
- Does the server need client identification (certificate)?
- How is the Luna setup and the server matched together?
You did not tell the plugin, but a guess is Apache Axis2. Go and check its documentation, and access Apache support if there is no success that way.
Tauno Voipio
FUDForum. Page generated in 0.08284 seconds
