clone private git [message #1728451] |
Mon, 04 April 2016 12:41 |
Hello everybody,
I (non-successfully) tried to clone a GitHub repo. This repo is private. When Oomph executes the clone task below it says that everything worked (no error message nor any other failure indication) but the repo isn't on my hard drive. Did I do something wrong in the task setup?
<setupTask
xsi:type="git:GitCloneTask"
id="git.clone"
remoteURI="myUserName/myRepo.git">
<annotation
source="http://www.eclipse.org/oomph/setup/InducedChoices">
<detail
key="inherit">
<value>github.remoteURIs</value>
</detail>
<detail
key="label">
<value>${scope.project.label} Github repository</value>
</detail>
<detail
key="target">
<value>remoteURI</value>
</detail>
</annotation>
<description>${scope.project.label}</description>
</setupTask>
This is what the eclipse wizard produces.
Thanks a lot for your responses
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live" - John Woods
Re: clone private git [message #1728680 is a reply to message #1728451] |
Wed, 06 April 2016 12:03 |
Ed Merks Messages: 33142 Registered: July 2009 |
Steffen,
Comments below.
On 04.04.2016 14:41, Steffen Holzer wrote:
> Hello everybody,
We've done that successfully, so there's nothing so special involved...
How does it say that? You see the messages in the log that it's
actually cloning?
> <setupTask
> id="git.clone"
> <annotation
> <detail
> key="inherit">
> </detail>
> <detail
> key="label">
> </detail>
> <detail
> key="target">
> </detail>
> </annotation>
> </setupTask>
If you do Help -> Perform Setup Tasks... and enable Show all triggered
tasks is the clone task there? Is it enable? If you select it and look
at the properties, the Location property should show where it is on the
file system and if the task is disabled there should be a valid clone
located at this location...
Ed Merks
FUDForum. Page generated in 0.02700 seconds
