Home » Eclipse Projects » Kura » Mqtt message capacity(KuraStoreCapacityReachedException)
Mqtt message capacity [message #1727843] |
Mon, 28 March 2016 11:28 |
Said Ucar Messages: 56 Registered: June 2015 |
Member |
I started to receive KuraStoreCapacityReachedException in my logs. I have very intense data flow over my raspberry, kura. The full exception logs below if you need. My question is, what is the meaning of this exception and how can I avoid that?
AFAIK, mqtt is specially designed for intense data flow for sensor devices etc. I think there are 2-3 thousand (max.) message published and there is an store exception. It doesn't seems reasonable for me.
Best Regards,
Said.
2016-03-28 11:21:04,552 [pool-24-thread-2] INFO o.e.k.c.d.DataServiceImpl - Storing message on topic :test, priority: 5
2016-03-28 11:21:04,554 [pool-24-thread-2] ERROR o.e.k.c.d.s.DbDataStore - Store capacity exceeded
2016-03-28 11:21:04,555 [pool-24-thread-2] WARN c.g.k.e.r.ReadSerial - Exception cought in message read/publish cycle
org.eclipse.kura.KuraStoreCapacityReachedException: "Error performing operation on store. Store capacity exceeded"
at org.eclipse.kura.core.data.store.DbDataStore.store(DbDataStore.java:198)
at org.eclipse.kura.core.data.DataServiceImpl.publish(DataServiceImpl.java:441)
at com.gohmega.kura.excelsior.runnable.ReadSerial.run(ReadSerial.java:76)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Re: Mqtt message capacity [message #1782307 is a reply to message #1727843] |
Wed, 21 February 2018 14:58 |
Ahmad Arif Messages: 10 Registered: February 2018 |
Hi all,
I have faced this issue but it disappeared, don't know how. I am facing some other issues my console logs are
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://19.fwk1179381257:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://19.fwk1179381257:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
19:17:21,444 [Component Resolve Thread] INFO BluetoothServiceImpl:35 - Activating Bluetooth Service...
!SESSION 2018-03-02 19:17:19.932 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_161
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -dev file:C:/Users/Ahmad.arif/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Kura_Emulator_OSX/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
!ENTRY org.eclipse.equinox.jsp.jasper 4 0 2018-03-02 19:17:21.493
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper [13]
Unresolved requirement: Import-Package: org.apache.jasper.servlet; version="[0.0.0,8.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Framework is running in emulation mode
19:17:21,798 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO Activator:96 - Camel activator starting
19:17:21,805 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO Activator:102 - Camel activator started
19:17:21,905 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO log:192 - Logging initialized @2183ms to org.eclipse.jetty.util.log.Slf4jLog
osgi> 19:17:22,062 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO Server:373 - jetty-9.4.7.v20170914
19:17:22,166 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO session:364 - DefaultSessionIdManager workerName=node0
19:17:22,167 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO session:369 - No SessionScavenger set, using defaults
19:17:22,168 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO session:149 - Scavenging every 600000ms
19:17:22,248 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO ContextHandler:788 - Started o.e.j.s.ServletContextHandler@61c39870{/,null,AVAILABLE}
19:17:22,262 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO AbstractConnector:286 - Started ServerConnector@576d7020{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
19:17:22,262 [Start Level: Equinox Container: 1096356b-241e-0018-12eb-de0cdb50802d] INFO Server:441 - Started @2541ms
!ENTRY 1 0 2018-03-02 19:17:23.298
!MESSAGE [IAgent][VMCommander@17b501a4] [startServer] cannot connect to controller.
!STACK 0
org.tigris.mtoolkit.iagent.mbsa.MBSAException: java.net.ConnectException: Connection refused: connect (caused by java.net.ConnectException: Connection refused: connect)
at org.tigris.mtoolkit.iagent.mbsa.MBSASessionFactory.serverConnect(MBSASessionFactory.java:41)
at org.tigris.mtoolkit.iagent.internal.VMCommander.startServer(VMCommander.java:67)
at org.tigris.mtoolkit.iagent.internal.VMCommander.<init>(VMCommander.java:53)
at org.tigris.mtoolkit.iagent.internal.rpc.Activator.startController(Activator.java:108)
at org.tigris.mtoolkit.iagent.internal.rpc.Activator.registerControllerSupport(Activator.java:98)
at org.tigris.mtoolkit.iagent.internal.rpc.Activator.start(Activator.java:91)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at org.tigris.mtoolkit.iagent.mbsa.MBSASessionFactory.serverConnect(MBSASessionFactory.java:38)
... 21 more
!ENTRY org.eclipse.equinox.jsp.jasper.registry 4 0 2018-03-02 19:17:23.477
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper.registry [99]
Unresolved requirement: Import-Package: org.eclipse.equinox.jsp.jasper
-> Export-Package: org.eclipse.equinox.jsp.jasper; bundle-symbolic-name="org.eclipse.equinox.jsp.jasper"; bundle-version="1.0.500.v20150119-1358"; version="1.0.0"
!ENTRY org.eclipse.equinox.ds 1 0 2018-03-02 19:17:23.551
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.deployment.hook.DeploymentHookManager. The reference is: Reference[name = DeploymentHook, interface = org.eclipse.kura.deployment.hook.DeploymentHook, policy = dynamic, cardinality = 0..n, target = null, bind = bindHook, unbind = unbindHook]
19:17:23,565 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:155 - Loaded URL kura.properties: file:C:\Users\Ahmad.arif\eclipse-workspace/org.eclipse.kura.emulator/src/main/resources/kura.properties
19:17:23,566 [Component Resolve Thread (Bundle 155)] WARN SystemServiceImpl:218 - File does not exist: \tmp\kura\kura_custom.properties
19:17:23,566 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:271 - Kura has net admin? false
19:17:23,566 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:274 - Is Kura web interface enabled? true
19:17:23,566 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:277 - Kura version? KURA_3.1.1
19:17:23,567 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:434 - Kura home directory is /tmp/kura
19:17:23,568 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:440 - Kura snapshots directory is C:\Users\Ahmad.arif\eclipse-workspace/kura/snapshots
19:17:23,568 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:446 - Kura tmp directory is /tmp/kura/tmp
19:17:23,568 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:450 - Kura version KURA_3.1.1 is starting
19:17:23,572 [Component Resolve Thread (Bundle 155)] INFO HsqlDbServiceImpl:76 - activate...
19:17:23,572 [Component Resolve Thread (Bundle 155)] INFO HsqlDbServiceImpl:144 - Opening database with url: jdbc:hsqldb:file:C:\Users\Ahmad.arif\eclipse-workspace/kura/data/db/data;hsqldb.lock_file=false
19:17:23,927 [Component Resolve Thread (Bundle 155)] INFO CloudConnectionStatusServiceImpl:88 - Activating CloudConnectionStatus service...
19:17:23,941 [pool-5-thread-1] INFO LogStatusRunnable:44 - Notification LED off
19:17:23,952 [Component Resolve Thread (Bundle 155)] INFO BluetoothLeServiceImpl:33 - Activating Bluetooth Le Service...
19:17:23,955 [Component Resolve Thread (Bundle 155)] ERROR BluetoothLeServiceImpl:82 - Failed to start linux systemd bluetooth
java.io.IOException: Cannot run program "systemctl": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.startBluetoothSystemd(BluetoothLeServiceImpl.java:79)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.activate(BluetoothLeServiceImpl.java:34)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
... 21 more
19:17:23,956 [Component Resolve Thread (Bundle 155)] ERROR BluetoothLeServiceImpl:100 - Failed to start linux init.d bluetooth
java.io.IOException: Cannot run program "/etc/init.d/bluetooth": CreateProcess error=2, The system cannot find the file specified
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.startBluetoothInitd(BluetoothLeServiceImpl.java:92)
... 21 more
19:17:23,957 [Component Resolve Thread (Bundle 155)] ERROR BluetoothLeServiceImpl:110 - Failed to start linux bluetooth service
java.io.IOException: Cannot run program "bluetoothd": CreateProcess error=2, The system cannot find the file specified
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.startBluetoothDaemon(BluetoothLeServiceImpl.java:108)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.activate(BluetoothLeServiceImpl.java:35)
... 21 more
Native code library failed to load.
java.lang.UnsatisfiedLinkError: no tinyb in java.library.path
19:17:23,965 [Component Resolve Thread (Bundle 155)] ERROR BluetoothLeServiceImpl:40 - Failed to start bluetooth service
java.lang.UnsatisfiedLinkError: tinyb.BluetoothManager.getNativeAPIVersion()Ljava/lang/String;
at tinyb.BluetoothManager.getNativeAPIVersion(Native Method)
at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:217)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.activate(BluetoothLeServiceImpl.java:38)
19:17:23,969 [Component Resolve Thread (Bundle 155)] INFO BluetoothLeBeaconManagerImpl:62 - Activating Bluetooth Le Beacon Manager...
19:17:23,972 [Component Resolve Thread (Bundle 155)] INFO BluetoothLeIBeaconServiceImpl:38 - Activating Bluetooth Le IBeacon Service...
19:17:23,974 [Component Resolve Thread (Bundle 155)] INFO BluetoothLeEddystoneServiceImpl:38 - Activating Bluetooth Le Eddystone Service...
!ENTRY osgi.annotation 4 0 2018-03-02 19:17:23.990
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: osgi.annotation [160]
Unresolved requirement: Require-Capability: osgi.compile.time.only; filter:="(&(must.not.resolve=*)(!(must.not.resolve=*)))"
19:17:24,029 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:209 - activate...
19:17:24,030 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:1335 - Loading init configurations from: 1519990836589...
19:17:24,236 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:1290 - Creating configuration with pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and factory pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
19:17:24,236 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:408 - Creating new configuration for factory pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
19:17:24,237 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:411 - Updating newly created configuration for pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
19:17:24,257 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....
19:17:24,257 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....Done
19:17:24,257 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:1290 - Creating configuration with pid: org.eclipse.kura.cloud.CloudService and factory pid: org.eclipse.kura.cloud.CloudService
19:17:24,257 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:408 - Creating new configuration for factory pid org.eclipse.kura.cloud.CloudService and pid org.eclipse.kura.cloud.CloudService
19:17:24,257 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:411 - Updating newly created configuration for pid org.eclipse.kura.cloud.CloudService
19:17:24,262 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....
19:17:24,262 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....Done
19:17:24,262 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:1290 - Creating configuration with pid: org.eclipse.kura.data.DataService and factory pid: org.eclipse.kura.data.DataService
19:17:24,262 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:408 - Creating new configuration for factory pid org.eclipse.kura.data.DataService and pid org.eclipse.kura.data.DataService
19:17:24,263 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:411 - Updating newly created configuration for pid org.eclipse.kura.data.DataService
19:17:24,268 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....
19:17:24,268 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....Done
19:17:24,276 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:1290 - Creating configuration with pid: org.eclipse.kura.db.H2DbService and factory pid: org.eclipse.kura.core.db.H2DbService
19:17:24,276 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:408 - Creating new configuration for factory pid org.eclipse.kura.core.db.H2DbService and pid org.eclipse.kura.db.H2DbService
19:17:24,276 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:411 - Updating newly created configuration for pid org.eclipse.kura.db.H2DbService
19:17:24,281 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....
19:17:24,281 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....Done
19:17:24,294 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:223 - Trackers being opened...
19:17:24,294 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:226 - Only tracking relevant services
19:17:24,295 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:659 - Registering SelfConfiguringComponent - org.eclipse.kura.wire.WireService....
19:17:24,295 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:667 - Registering SelfConfiguringComponent - org.eclipse.kura.wire.WireService....Done
19:17:24,433 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.cloud.CloudService ...
19:17:24,435 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.cloud.CloudService
19:17:24,442 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.cloud.CloudService
19:17:24,442 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.cloud.app.command.CommandCloudApp ...
19:17:24,442 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
19:17:24,447 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
19:17:24,452 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.web.Console ...
19:17:24,452 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.web.Console
19:17:24,457 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.web.Console
19:17:24,476 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance ...
19:17:24,476 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
19:17:24,480 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
19:17:24,499 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport ...
19:17:24,504 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
19:17:24,504 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.core.db.H2DbService ...
19:17:24,508 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.db.H2DbService
19:17:24,508 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.data.DataService ...
19:17:24,512 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.data.DataService
19:17:24,513 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.core.db.H2DbServer ...
19:17:24,513 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.ssl.SslManagerService ...
19:17:24,513 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.ssl.SslManagerService
19:17:24,518 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.ssl.SslManagerService
19:17:24,524 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.camel.xml.XmlRouterComponent ...
19:17:24,524 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
19:17:24,529 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
19:17:24,543 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.internal.rest.provider.RestService ...
19:17:24,543 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
19:17:24,547 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
19:17:24,555 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.position.PositionService ...
19:17:24,555 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.position.PositionService
19:17:24,560 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.position.PositionService
19:17:24,601 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.CloudSubscriber ...
19:17:24,601 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.RegexFilter ...
19:17:24,601 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.Logger ...
19:17:24,602 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordFilter ...
19:17:24,602 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.Fifo ...
19:17:24,602 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.Timer ...
19:17:24,602 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.CloudPublisher ...
19:17:24,602 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordStore ...
19:17:24,606 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.watchdog.WatchdogService ...
19:17:24,611 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.watchdog.WatchdogService
19:17:24,616 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.clock.ClockService ...
19:17:24,621 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.clock.ClockService
19:17:24,625 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordStore ...
19:17:24,625 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordFilter ...
19:17:24,628 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance ...
19:17:24,628 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
19:17:24,633 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
19:17:24,638 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 ...
19:17:24,638 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
19:17:24,643 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
19:17:24,648 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.camel.cloud.factory.CamelFactory ...
19:17:24,658 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:610 - Registering metatype pid: org.eclipse.kura.demo.heater.Heater ...
19:17:24,658 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:693 - Merging configuration for pid: org.eclipse.kura.demo.heater.Heater
19:17:24,663 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:852 - Seeding updated configuration for pid: org.eclipse.kura.demo.heater.Heater
19:17:24,667 [Component Resolve Thread (Bundle 155)] INFO H2DbHelper:49 - activating...
19:17:24,667 [Component Resolve Thread (Bundle 155)] INFO H2DbHelper:41 - Default H2DbService instance configuration found
19:17:24,667 [Component Resolve Thread (Bundle 155)] INFO H2DbHelper:51 - activating...done
!ENTRY org.eclipse.equinox.ds 1 0 2018-03-02 19:17:24.671
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.configuration.CloudConfigurationHandler. The reference is: Reference[name = CloudService, interface = org.eclipse.kura.cloud.CloudService, policy = dynamic, cardinality = 0..1, target = (kura.service.pid=org.eclipse.kura.cloud.CloudService), bind = setCloudService, unbind = unsetCloudService]
19:17:24,674 [Component Resolve Thread (Bundle 155)] INFO CertificatesManager:66 - Bundle org.eclipse.kura.core.certificates.CertificatesManager has started!
19:17:24,686 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:87 - activating...
19:17:24,686 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:96 - updating...
19:17:24,687 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:305 - Opening database with url: jdbc:h2:mem:kuradb
!ENTRY org.eclipse.osgi 4 0 2018-03-02 19:17:24.690
!MESSAGE Bundle initial@reference:file:org.eclipse.equinox.jsp.jasper_1.0.500.v20150119-1358.jar was not resolved.
!MESSAGE Bundle initial@reference:file:org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2018-03-02 19:17:24.691
!MESSAGE Bundle initial@reference:file:../../../common/repository/plugins/osgi.annotation_6.0.1.201503162037.jar was not resolved.
19:17:24,788 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:145 - updating...done
19:17:24,788 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:91 - activating...done
19:17:24,794 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....
19:17:24,794 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....Done
19:17:24,797 [Component Resolve Thread (Bundle 155)] INFO ClockServiceImpl:57 - Activate. Current Time: Fri Mar 02 19:17:24 PKT 2018
19:17:24,797 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....
19:17:24,797 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....Done
19:17:24,822 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....
19:17:24,823 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....Done
19:17:24,830 [Component Resolve Thread (Bundle 155)] INFO Console:127 - activate...
19:17:25,302 [Component Resolve Thread (Bundle 155)] INFO FileServlet:93 - Servlet org.eclipse.kura.web.server.servlet.FileServlet initialized
19:17:25,304 [Component Resolve Thread (Bundle 155)] INFO FileServlet:104 - DiskFileItemFactory.DEFAULT_SIZE_THRESHOLD: 10240
19:17:25,304 [Component Resolve Thread (Bundle 155)] INFO FileServlet:105 - DiskFileItemFactory: using size threshold of: 10240
19:17:25,321 [Component Resolve Thread (Bundle 155)] INFO Console:174 - postInstalledEvent() :: posting KuraConfigReadyEvent
19:17:25,322 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.web.Console....
19:17:25,322 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.web.Console....Done
19:17:25,326 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....
19:17:25,327 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....Done
19:17:25,329 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:96 - updating...
19:17:25,329 [Component Resolve Thread (Bundle 155)] INFO H2DbServiceImpl:145 - updating...done
19:17:25,336 [Component Resolve Thread (Bundle 155)] INFO SslManagerServiceImpl:121 - activate...
19:17:25,338 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....
19:17:25,338 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....Done
19:17:25,344 [Component Resolve Thread (Bundle 155)] INFO MqttDataTransport:170 - Activating org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport...
19:17:25,345 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:541 - executing: InetAddress.getLocalHost windows
19:17:25,408 [Component Resolve Thread (Bundle 155)] INFO SystemServiceImpl:554 - macAddress A0:B3:CC:F7:F1:07
19:17:25,417 [Component Resolve Thread (Bundle 155)] INFO DataServiceImpl:116 - Activating org.eclipse.kura.data.DataService...
19:17:25,417 [Component Resolve Thread (Bundle 155)] INFO DataServiceImpl:669 - Get Throttle with burst length 1 and send a message every 1000 millis
19:17:25,420 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
19:17:25,421 [Component Resolve Thread (Bundle 155)] INFO DataServiceImpl:158 - H2DbService instance found
19:17:25,448 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
19:17:25,452 [Component Resolve Thread (Bundle 155)] INFO CloudCallServiceImpl:76 - Activating...
19:17:25,456 [Component Resolve Thread (Bundle 155)] INFO CloudServiceImpl:179 - activate org.eclipse.kura.cloud.CloudService...
19:17:25,458 [Component Resolve Thread (Bundle 155)] INFO Cloudlet:88 - Getting CloudApplicationClient for CONF-V1...
19:17:25,468 [Component Resolve Thread (Bundle 155)] INFO Cloudlet:88 - Getting CloudApplicationClient for ASSET-V1...
19:17:25,473 [Component Resolve Thread (Bundle 155)] INFO CommandCloudApp:85 - Cloudlet CMD-V1 has started with config!
19:17:25,473 [Component Resolve Thread (Bundle 155)] INFO Cloudlet:88 - Getting CloudApplicationClient for CMD-V1...
19:17:25,473 [Component Resolve Thread (Bundle 155)] INFO CommandCloudApp:95 - updated...: org.eclipse.equinox.internal.ds.impl.ReadOnlyDictionary@71baf89f
19:17:25,474 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....
19:17:25,474 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....Done
19:17:25,478 [Component Resolve Thread (Bundle 155)] INFO AbstractCamelComponent:40 - Starting camel router
19:17:25,484 [Component Resolve Thread (Bundle 155)] INFO CamelRunner:433 - Starting...
19:17:25,484 [Component Resolve Thread (Bundle 155)] INFO CamelRunner:464 - Stopping...
19:17:25,658 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:2800 - Apache Camel 2.17.2 (CamelContext: camel-1) is starting
19:17:25,659 [Component Resolve Thread (Bundle 155)] INFO ManagedManagementStrategy:191 - JMX is enabled
19:17:25,857 [Component Resolve Thread (Bundle 155)] INFO DefaultRuntimeEndpointRegistry:203 - Runtime endpoint registry is in extended mode gathering usage statistics of all incoming and outgoing endpoints (cache limit: 1000)
19:17:25,858 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:3039 - AllowUseOriginalMessage is enabled. If access to the original message is not needed, then its recommended to turn this option off as it may improve performance.
19:17:25,858 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:3049 - StreamCaching is not in use. If using streams then its recommended to enable stream caching. See more details at http://camel.apache.org/stream-caching.html
19:17:25,858 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:2840 - Total 0 routes, of which 0 are started.
19:17:25,859 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:2841 - Apache Camel 2.17.2 (CamelContext: camel-1) started in 0.201 seconds
19:17:25,859 [Component Resolve Thread (Bundle 155)] INFO CamelRunner:618 - Setting routes...
19:17:26,347 [Component Resolve Thread (Bundle 155)] INFO OsgiDefaultCamelContext:3570 - Route: route1 started and consuming from: Endpoint[kura-cloud://myapp/xmltopic]
19:17:26,348 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....
19:17:26,348 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....Done
19:17:26,359 [Component Resolve Thread (Bundle 155)] INFO RestService:49 - activating...
19:17:26,359 [Component Resolve Thread (Bundle 155)] INFO RestService:60 - updating...
19:17:26,364 [Component Resolve Thread (Bundle 155)] INFO RestService:62 - updating...done
19:17:26,364 [Component Resolve Thread (Bundle 155)] INFO RestService:51 - activating...done
19:17:26,365 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....
19:17:26,365 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....Done
19:17:26,369 [Component Resolve Thread (Bundle 155)] INFO ClockServiceImpl:68 - Updated...
19:17:26,373 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....
19:17:26,373 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....Done
19:17:26,380 [Component Resolve Thread (Bundle 155)] INFO CloudDeploymentHandlerV2:241 - Cloud Deployment v2 is starting
19:17:26,381 [Component Resolve Thread (Bundle 155)] INFO Cloudlet:88 - Getting CloudApplicationClient for DEPLOY-V2...
19:17:26,384 [Component Resolve Thread (Bundle 155)] INFO InstallImpl:211 - Ready to send Confirmations
19:17:26,384 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....
19:17:26,384 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....Done
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:93 - Activating Heater...
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - component.name: org.eclipse.kura.demo.heater.Heater
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - temperature.initial: 10.0
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - program.stopTime: 22:00
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - objectClass: [Ljava.lang.String;@5cab5f44
19:17:26,388 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - manual.setPoint: 15.0
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - publish.semanticTopic: data
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - program.setPoint: 20.5
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - mode: Program
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - kura.service.pid: org.eclipse.kura.demo.heater.Heater
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - CloudService.target: (kura.service.pid=org.eclipse.kura.cloud.CloudService)
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - publish.rate: 2
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - service.pid: org.eclipse.kura.demo.heater.Heater
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - temperature.increment: 0.25
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - component.id: 54
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - publish.retain: false
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - publish.qos: 0
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:97 - Activate - program.startTime: 06:00
19:17:26,389 [Component Resolve Thread (Bundle 155)] INFO Heater:104 - Getting CloudClient for heater...
19:17:26,390 [Component Resolve Thread (Bundle 155)] INFO Heater:115 - Activating Heater... Done.
19:17:26,391 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:634 - Registering ConfigurableComponent - org.eclipse.kura.demo.heater.Heater....
19:17:26,391 [Component Resolve Thread (Bundle 155)] INFO ConfigurationServiceImpl:650 - Registering ConfigurableComponent - org.eclipse.kura.demo.heater.Heater....Done
data
19:17:26,421 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:26,433 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:26,433 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@33cf6a03
19:17:26,433 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
19:17:26,438 [HouseKeeperTask] INFO HouseKeeperTask:41 - HouseKeeperTask started.
19:17:26,438 [HouseKeeperTask] INFO HouseKeeperTask:52 - HouseKeeperTask: Delete confirmed messages...
19:17:26,441 [HouseKeeperTask] INFO HouseKeeperTask:61 - HouseKeeperTask ended.
data
19:17:28,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:28,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:28,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@2e0ccaa6
19:17:28,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:30,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:30,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:30,393 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@52b7f223
19:17:30,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:32,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:32,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:32,393 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@1021cafa
19:17:32,393 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:34,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:34,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:34,393 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@58f6258f
19:17:34,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:36,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:36,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:36,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@10678dcd
19:17:36,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:38,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:38,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:38,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@7d2c5308
19:17:38,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:40,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:40,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:40,393 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@6344204d
19:17:40,393 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:42,391 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:42,393 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:42,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@a77bbf7
19:17:42,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:44,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:44,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:44,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
19:17:44,395 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@26d25691
data
19:17:46,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:46,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:46,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@39f9e550
19:17:46,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:48,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:48,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:48,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@7b7dec6a
19:17:48,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:50,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:50,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:50,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
19:17:50,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@4c6258f1
data
19:17:52,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:52,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:52,395 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@7830e932
19:17:52,395 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:54,393 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:54,395 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:54,395 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@e155001
19:17:54,395 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:56,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:56,395 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:56,395 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@1a1fe315
19:17:56,395 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
19:17:58,392 [] INFO DataServiceImpl:531 - Storing message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:58,394 [] INFO DataServiceImpl:534 - Stored message on topic :#account-name/#client-id/heater/data, priority: 5
19:17:58,394 [] INFO Heater:274 - Published to data message: org.eclipse.kura.message.KuraPayload@44e48577
19:17:58,394 [DataServiceImpl:Submit] INFO DataServiceImpl:821 - DataPublisherService not connected
data
If someone knows the solution, Kindly help.
Kind Regards,
Ahmad Arif
[Updated on: Fri, 02 March 2018 14:37] Report message to a moderator
Current Time: Fri Apr 26 11:54:19 GMT 2024
Powered by FUDForum. Page generated in 0.03618 seconds
