| Parse error - keyword used as parameter value [message #1727692] |
Fri, 25 March 2016 07:33  |
I'm trying to parse language where the naming convention is not very strict and the keywords can be used as parameters (name or value). I have the following dummy grammar (each statement should be on a separate line) :
grammar test.org.xtext.example.mydsl.MyDsl hidden (WS)
generate myDsl "http://www.org.test/xtext/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
(statements+=Statement EOL+)*
statements+=Statement EOL*
Statement:
ImportStatement|
RunStatement
RunStatement:
{RunQueryStatement} 'RUN' 'PROC' parameterList+=ParameterDefinition+
ParameterDefinition:
{VariableDefinition} paramName=ID '=' paramValue=(ID|STRING)
ImportStatement:
{ImportProcSatatement} 'IMPORT' 'PROC' 'FROM' fileName=STRING
terminal ID:
(!('\r'|'\n'|' '|'\t'|'"'|"'"|'='))+
terminal EOL:
('\r'? '\n')
terminal WS :
(' '|'\t')+
terminal STRING :
'"' ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|'"') )* '"' |
"'" ( '\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\'|"'") )* "'"
When parsing the following code :
IMPORT PROC FROM 'myfile'
RUN PROC param=PROC
I get an error on the second line "no viable alternative at input 'PROC'".
How can I change the rules to be able to parse this script?
FUDForum. Page generated in 0.03873 seconds
