| Concurrent subscribe, unsubscribe and publish operations using same MqttClient instance [message #1727001] |
Fri, 18 March 2016 03:50  |
I am using Paho Mqtt V3 (version 1.0.2) in my application which is running in production now. My application is a rest based application running in Tomcat and connects to ActiveMQ broker (which is configured to use mqtt+nio as transport connector). The app creates 6-7 instances of MqttClient in the same JVM and each MqttClient instance performs concurrent subscribe/unsubscribe/publish operations.
Recently we have been seeing many instances of the following exception in our logs :
Timed out waiting for a response from the server (32000)
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:31)
at org.eclipse.paho.client.mqttv3.internal.ClientState.checkForActivity(ClientState.java:564)
at org.eclipse.paho.client.mqttv3.internal.ClientComms.checkForActivity(ClientComms.java:660)
at org.eclipse.paho.client.mqttv3.TimerPingSender$PingTask.run(TimerPingSender.java:77)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
To reproduce this issue, I just wrote a stand-alone Java class which creates 5 instances of MqttClient in 5 threads. Each thread then spawns further 5 threads all of which use the same MqttClient instance to perform subscribe/publish operations continuously. After running this for about 5-15 minutes, I get the "Timed out" exception. However, there are no errors/warnings in the ActiveMQ logs.
Is my usage of MqttClient wrong in any way?
I have attached the sample concurrent publisher and subscriber classes that can be used to reproduce the problem.
Any help or pointers would be greatly appreciated.
Shobhana
| Re: Concurrent subscribe, unsubscribe and publish operations using same MqttClient instance [message #1731504 is a reply to message #1727915] |
Fri, 06 May 2016 06:05  |
I would try using a different MQTT Broker instead of a different connector type, as by switching to a JMS connector you'll no longer be hitting any MQTT code at all on the ActiveMQ side. Try with something like Mosquitto, if you see the same results then it might be worth making sure that if you are listening for any callbacks that you are not holding them up unnecessarily before releasing them as that can cause time outs in certain cases.
FUDForum. Page generated in 0.27370 seconds
