Re: [EMF Forms] Table Control : Column Width [message #1727048 is a reply to message #1726986] |
Fri, 18 March 2016 12:59 |
1. The validation column will be shown for all tables which are not readonly. However you may create a template model including a TableValidationStyleProperty. Here you can influence the column width of the validation column, so you could set it to 0.
2. We have some options to influence the column widths.
Using the nightly build you may add VWidthConfigurations to the table control to influence the column width-weights.
Besides that the column width is depending on the ECPCellEditor which gets used as the Editor for the column.
Johannes
Johannes Faltermeier
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] Table Control : Column Width [message #1727610 is a reply to message #1727431] |
Thu, 24 March 2016 12:43 |
which version are you using? There was a bug in an older version when 0 was not working, but you can set the width to 1 for example.
Regarding the selector. If you want to change the column for all TableControls you should use a ViewModelElement Selector and select the TableControl class.
If you want to change it for one table control use the DMR-Selector and point it to the Table's EReference, as you did in your example.
Cheers
FUDForum. Page generated in 0.03918 seconds
