Home » Eclipse Projects » Sirius » add a listener to a diagram element
add a listener to a diagram element [message #1726631] Tue, 15 March 2016 05:26 Go to next message
Hi everybody,
For my project I have to listen to an element of a diagram an do some actions when the user clic or modify something on it.
For exemple when a field of an element is changed I want to automaticly change the value of another field. Do you know how to do that ?
Another thing I need to do (more complicated I think) is to get the layout position of an element (x and y) on the diagram and store those values on a field of it. For exemple if I drag the element on the diagram from position x=50, y=50 to x=100, y=100 I need that field of this element to automaticly change to x=100 and y=100.
I tried to modify the .aird file but it makes the diagram crash.
Is this something possible to do with Sirius ?
Thank you !
Alex
[Updated on: Wed, 16 March 2016 04:58] by Moderator
Re: add a listener to a diagram element [message #1726781 is a reply to message #1726631] Wed, 16 March 2016 09:24 Go to previous messageGo to next message
After some research It seems like it is possible to do what I need with the GMF Runtime plugin, the problem is that I have absolutely no idea on how to access that plugin with a Sirius diagram. Maybe I need to create and open the diagrams programmaticly ?
Re: add a listener to a diagram element [message #1726790 is a reply to message #1726781] Wed, 16 March 2016 10:00 Go to previous messageGo to next message
Sirius is based on GMF, and GMF based on GEF, then you can API of these
frameworks also.
For your need you can use a precommit, i.e. a ResourceSetListener, to
update some model elements according to some changes. See [1]
[1]
http://www.linuxtopia.org/online_books/eclipse_documentation/eclipse_emf_model_transaction_developer_guide/topic/org.eclipse.emf.transaction.doc/references/overview/eclipse_emf_model_transaction_listeners.html
Best Regards.
Esteban Dugueperoux - Obeo
Re: add a listener to a diagram element [message #1726812 is a reply to message #1726790] Wed, 16 March 2016 12:16 Go to previous messageGo to next message
Thanks for your reply,
I also found this post with approximately the same question as mine : https://www.eclipse.org/forums/index.php/t/1068712/
The answer says that it's possible to use the org.eclipse.sirius.diagram.ui.business.api.view.SiriusGMFHelper.getGMFNode(DDiagramElement) method to do it.
As I am not really familiar with Siruis I don't know witch solution is the best (between the pre-commit and the helper) and I don't kwow how to get the DDiagramElement programmaticly. Do you have an idea ?
Alex.
Re: add a listener to a diagram element [message #1726813 is a reply to message #1726790] Wed, 16 March 2016 12:17 Go to previous messageGo to next message
MULTIPLE POST BUG : TO DELETE
[Updated on: Wed, 16 March 2016 12:27] by Moderator
Re: add a listener to a diagram element [message #1726814 is a reply to message #1726790] Wed, 16 March 2016 12:18 Go to previous messageGo to next message
[Updated on: Wed, 16 March 2016 12:28] by Moderator
Re: add a listener to a diagram element [message #1726815 is a reply to message #1726790] Wed, 16 March 2016 12:18 Go to previous messageGo to next message
Re: add a listener to a diagram element [message #1726816 is a reply to message #1726790] Wed, 16 March 2016 12:18 Go to previous messageGo to next message
No Message Body
Re: add a listener to a diagram element [message #1726818 is a reply to message #1726790] Wed, 16 March 2016 12:19 Go to previous messageGo to next message
No Message Body
Re: add a listener to a diagram element [message #1726819 is a reply to message #1726790] Wed, 16 March 2016 12:19 Go to previous messageGo to next message
No Message Body
Re: add a listener to a diagram element [message #1726820 is a reply to message #1726790] Wed, 16 March 2016 12:19 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 16 March 2016 12:29] by Moderator
Re: add a listener to a diagram element [message #1727748 is a reply to message #1726790] Sat, 26 March 2016 12:47 Go to previous messageGo to next message
Hi Esteban,
Could you please elaborate more on registering the listeners as an extension?
- Should we add the extension in the EMF project plugin or to the Sirius (design) project plug-in ?
- What is the Editing Domain ? is it our EMF project ?
<extension point="org.eclipse.emf.transaction.listeners">
    <listener class="org.eclipse.example.MyListener">
       <editingDomain id="org.eclipse.example.MyEditingDomain"/>
    </listener>
</extension>
Parsa
[Updated on: Sat, 26 March 2016 12:52] by Moderator
Re: add a listener to a diagram element [message #1853165 is a reply to message #1727748] Tue, 21 June 2022 09:39 Go to previous message
Hi parsa,
do you have a solution?
Previous Topic:Validation of the odesign file fails
Next Topic:Add a listener to a diagram element on sirius web
Current Time: Mon Jun 23 14:20:38 EDT 2025
Powered by FUDForum. Page generated in 0.04313 seconds
