Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2
[EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1726166] Thu, 10 March 2016 04:26 Go to next message
Me again... :-)
I wanted to check out the new reloaded EMF Forms Ecore Editor and
Genmodel Editor.
So I got a new Mars.2 Eclipse installallation and followed this tutorial :
http://eclipsesource.com/blogs/tutorials/emf-forms-editors/#ecoreeditor
I installed the "EMF Forms Ecore Editor inkl sources" from
http://download.eclipse.org/ecp/releases/releases_18/
restarted eclipse, but the new editors do not show up unter "open with"
--> other (Screenshot)
When I check the eclipse installation via "About --> Installation
details" the feature shows up correctly (see attached Screenshot)
Did I miss something? Any other feature I need to install/have?
cheers
Oliver
Re: [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1726184 is a reply to message #1726166] Thu, 10 March 2016 07:25 Go to previous messageGo to next message
I just tried it with a Mars.2 Modeling Edition and it is working for me. Which Eclipse Package did you use as a starting point?
Re: [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1726199 is a reply to message #1726184] Thu, 10 March 2016 09:06 Go to previous messageGo to next message
Hi Johannes,
we use an Oomph generated custom eclipse...that is based on "Eclipse DSL
Tools" with some additions from other repositories...
I just downloaded a Modelling Edition and now it works here too :-)
So I think this is some missing feature in our eclipse...
The question is...which one ?
cheers
Oliver
Am 10.03.2016 um 13:25 schrieb Johannes Faltermeier:
Re: [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1726208 is a reply to message #1726199] Thu, 10 March 2016 09:31 Go to previous messageGo to next message
Hello Johannes
Update:
I just checked the osgi host console in our (dsl based) eclipse, and saw
that the bundle org.eclipse.emfforms.editor_1.8.0.20160216-1319 is in
status "STARTING" like all the other emfforms bundles!
..... but I cant see unresolved dependencies for
"org.eclipse.emfforms.editor"
console output in attached textfile!
Do you have an idea, what is wrong here ?
Best regards
Oliver
osgi> ss emfforms
"Framework is launched."
id State Bundle
507 STARTING org.eclipse.emfforms.common_1.8.0.20160216-1319
508 STARTING org.eclipse.emfforms.core.services_1.8.0.20160216-1319
509 STARTING org.eclipse.emfforms.core.services.databinding.featurepath_1.8.0.20160216-1319
510 STARTING org.eclipse.emfforms.core.services.databinding.index_1.8.0.20160216-1319
511 STARTING org.eclipse.emfforms.core.services.databinding.mapping_1.8.0.20160216-1319
512 STARTING org.eclipse.emfforms.core.services.domainexpander.default_1.8.0.20160216-1319
513 STARTING org.eclipse.emfforms.core.services.domainexpander.index_1.8.0.20160216-1319
514 STARTING org.eclipse.emfforms.core.services.domainexpander.mapping_1.8.0.20160216-1319
515 STARTING org.eclipse.emfforms.core.services.domainexpander.table_1.8.0.20160216-1319
516 STARTING org.eclipse.emfforms.core.services.editsupport_1.8.0.20160216-1319
517 STARTING org.eclipse.emfforms.core.services.emf_1.8.0.20160216-1319
518 STARTING org.eclipse.emfforms.core.services.emfspecificservice_1.8.0.20160216-1319
519 STARTING org.eclipse.emfforms.core.services.legacy_1.8.0.20160216-1319
520 STARTING org.eclipse.emfforms.core.services.locale.default_1.8.0.20160216-1319
521 STARTING org.eclipse.emfforms.core.services.mappingprovider.default_1.8.0.20160216-1319
522 STARTING org.eclipse.emfforms.core.services.mappingprovider.table_1.8.0.20160216-1319
523 STARTING org.eclipse.emfforms.core.services.structuralchange_1.8.0.20160216-1319
524 STARTING org.eclipse.emfforms.core.services.structuralchange.default_1.8.0.20160216-1319
525 STARTING org.eclipse.emfforms.core.services.structuralchange.index_1.8.0.20160216-1319
526 STARTING org.eclipse.emfforms.core.services.structuralchange.mapping_1.8.0.20160216-1319
527 STARTING org.eclipse.emfforms.core.services.structuralchange.table_1.8.0.20160216-1319
528 STARTING org.eclipse.emfforms.editor_1.8.0.20160216-1319
529 STARTING org.eclipse.emfforms.localization_1.8.0.20160216-1319
530 RESOLVED org.eclipse.emfforms.setup.base_1.8.0.20160216-1319
531 STARTING org.eclipse.emfforms.swt.core_1.8.0.20160216-1319
532 STARTING org.eclipse.emfforms.swt.core.di_1.8.0.20160216-1319
533 STARTING org.eclipse.emfforms.swt.core.di.extension_1.8.0.20160216-1319
534 STARTING org.eclipse.emfforms.swt.core.plugin_1.8.0.20160216-1319
535 STARTING org.eclipse.emfforms.swt.table_1.8.0.20160216-1319
536 STARTING org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319
537 STARTING org.eclipse.emfforms.view.model.localization_1.8.0.20160216-1319
osgi> bundle 528
org.eclipse.emfforms.editor_1.8.0.20160216-1319 [528]
Id=528, Status=STARTING Data Root=C:\ws_intern\eclipse\sbider-2.0.3\eclipse\configuration\org.eclipse.osgi\528\data
"No registered services."
No services in use.
Exported packages
org.eclipse.emfforms.internal.editor; version="1.8.0"[exported]
org.eclipse.emfforms.internal.editor.handlers; version="1.8.0"[exported]
org.eclipse.emfforms.internal.editor.toolbaractions; version="1.8.0"[exported]
org.eclipse.emfforms.internal.editor.ui; version="1.8.0"[exported]
org.eclipse.emfforms.spi.editor; version="1.8.0"[exported]
org.eclipse.emfforms.spi.editor.helpers; version="1.8.0"[exported]
Imported packages
javax.accessibility; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.activation; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.activity; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.annotation; version="1.2.0" <javax.annotation_1.2.0.v201401042248 [70]>
javax.annotation; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.annotation.processing; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.annotation.security; version="1.2.0" <javax.annotation_1.2.0.v201401042248 [70]>
javax.annotation.sql; version="1.2.0" <javax.annotation_1.2.0.v201401042248 [70]>
javax.crypto; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.crypto.interfaces; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.crypto.spec; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.event; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.metadata; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.plugins.bmp; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.plugins.jpeg; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.imageio.stream; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.inject; version="1.0.0" <javax.inject_1.0.0.v20091030 [72]>
javax.jws; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.jws.soap; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.lang.model; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.lang.model.element; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.lang.model.type; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.lang.model.util; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.loading; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.modelmbean; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.monitor; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.openmbean; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.relation; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.remote; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.remote.rmi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.management.timer; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.naming; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.naming.directory; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.naming.event; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.naming.ldap; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.naming.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.net; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.net.ssl; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.print; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.print.attribute; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.print.attribute.standard; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.print.event; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.rmi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.rmi.CORBA; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.rmi.ssl; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.script; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth.callback; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth.kerberos; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth.login; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.auth.x500; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.cert; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.security.sasl; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sound.midi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sound.midi.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sound.sampled; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sound.sampled.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sql; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sql.rowset; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sql.rowset.serial; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.sql.rowset.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.border; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.colorchooser; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.event; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.filechooser; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf.basic; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf.metal; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf.multi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf.nimbus; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.plaf.synth; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.table; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.text; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.text.html; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.text.html.parser; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.text.rtf; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.tree; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.swing.undo; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.tools; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.transaction; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.transaction.xa; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind.annotation; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind.annotation.adapters; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind.attachment; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind.helpers; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.bind.util; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto.dom; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto.dsig; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto.dsig.dom; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto.dsig.keyinfo; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.crypto.dsig.spec; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.datatype; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.namespace; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.parsers; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.soap; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.stream; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.stream.events; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.stream.util; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.transform; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.transform.dom; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.transform.sax; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.transform.stax; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.transform.stream; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.validation; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.handler; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.handler.soap; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.http; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.soap; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.spi; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.spi.http; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.ws.wsaddressing; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
javax.xml.xpath; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.core.commands; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.commands.common; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.commands.contexts; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.commands.operations; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.commands.util; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.databinding; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.databinding.conversion; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.databinding.observable; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.observable.list; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.observable.map; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.observable.masterdetail; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.observable.set; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.observable.value; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.property; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.databinding.property.list; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.databinding.property.map; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.databinding.property.set; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.databinding.property.value; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.databinding.util; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.databinding.validation; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.internal.adapter; version="0.0.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.internal.boot; version="0.0.0" <org.eclipse.equinox.common_3.7.0.v20150402-1709 [546]>
org.eclipse.core.internal.commands.operations; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.internal.commands.util; version="0.0.0" <org.eclipse.core.commands_3.7.0.v20150422-0725 [143]>
org.eclipse.core.internal.content; version="0.0.0" <org.eclipse.core.contenttype_3.5.0.v20150421-2214 [144]>
org.eclipse.core.internal.databinding; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.internal.databinding.conversion; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.internal.databinding.identity; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.internal.databinding.observable; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.internal.databinding.observable.masterdetail; version="0.0.0" <org.eclipse.core.databinding.observable_1.5.0.v20150422-0725 [147]>
org.eclipse.core.internal.databinding.property; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.internal.databinding.property.list; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.internal.databinding.property.map; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.internal.databinding.property.set; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.internal.databinding.property.value; version="0.0.0" <org.eclipse.core.databinding.property_1.5.0.v20150422-0725 [148]>
org.eclipse.core.internal.databinding.validation; version="0.0.0" <org.eclipse.core.databinding_1.5.0.v20150422-0725 [145]>
org.eclipse.core.internal.dtree; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.events; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.jobs; version="0.0.0" <org.eclipse.core.jobs_3.7.0.v20150330-2103 [155]>
org.eclipse.core.internal.localstore; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.preferences; version="0.0.0" <org.eclipse.equinox.preferences_3.5.300.v20150408-1437 [590]>
org.eclipse.core.internal.preferences.exchange; version="0.0.0" <org.eclipse.equinox.preferences_3.5.300.v20150408-1437 [590]>
org.eclipse.core.internal.preferences.legacy; version="0.0.0" <org.eclipse.core.runtime_3.11.1.v20150903-1804 [160]>
org.eclipse.core.internal.properties; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.propertytester; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.refresh; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.registry; version="0.0.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.internal.registry.osgi; version="0.0.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.internal.registry.spi; version="0.0.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.internal.resources; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.resources.mapping; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.resources.projectvariables; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.resources.refresh.win32; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.runtime; version="0.0.0" <org.eclipse.core.runtime_3.11.1.v20150903-1804 [160]>
org.eclipse.core.internal.runtime; version="0.0.0" <org.eclipse.equinox.common_3.7.0.v20150402-1709 [546]>
org.eclipse.core.internal.utils; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.internal.watson; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources.filtermatchers; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources.mapping; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources.refresh; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources.team; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.resources.variableresolvers; version="0.0.0" <org.eclipse.core.resources_3.10.1.v20150725-1910 [158]>
org.eclipse.core.runtime; version="3.5.0" <org.eclipse.core.runtime_3.11.1.v20150903-1804 [160]>
org.eclipse.core.runtime; version="3.5.0" <org.eclipse.equinox.common_3.7.0.v20150402-1709 [546]>
org.eclipse.core.runtime; version="3.5.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.runtime.adaptor; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.core.runtime.content; version="0.0.0" <org.eclipse.core.contenttype_3.5.0.v20150421-2214 [144]>
org.eclipse.core.runtime.dynamichelpers; version="3.4.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.core.runtime.internal.adaptor; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.core.runtime.jobs; version="0.0.0" <org.eclipse.core.jobs_3.7.0.v20150330-2103 [155]>
org.eclipse.core.runtime.preferences; version="3.3.0" <org.eclipse.equinox.preferences_3.5.300.v20150408-1437 [590]>
org.eclipse.core.runtime.spi; version="3.4.0" <org.eclipse.equinox.registry_3.6.0.v20150318-1503 [591]>
org.eclipse.emf.codegen; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.ecore; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.generator; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.genmodel; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.genmodel.generator; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.genmodel.impl; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.genmodel.util; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.templates.edit; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.templates.editor; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.templates.model; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.ecore.templates.model.tests; version="0.0.0" <org.eclipse.emf.codegen.ecore_2.11.1.v20160208-0841 [300]>
org.eclipse.emf.codegen.jet; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.jmerge; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.merge.java; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.merge.java.facade; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.merge.java.facade.ast; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.merge.java.facade.jdom; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.merge.properties; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.codegen.util; version="0.0.0" <org.eclipse.emf.codegen_2.11.0.v20160208-0841 [299]>
org.eclipse.emf.common; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.common.archive; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.common.command; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.common.notify; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.common.notify.impl; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.common.ui; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.action; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.celleditor; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.dialogs; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.editor; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.viewer; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.ui.wizard; version="0.0.0" <org.eclipse.emf.common.ui_2.10.1.v20160208-0841 [306]>
org.eclipse.emf.common.util; version="0.0.0" <org.eclipse.emf.common_2.11.1.v20160208-0816 [305]>
org.eclipse.emf.databinding; version="0.0.0" <org.eclipse.emf.databinding_1.3.0.v20160208-0841 [315]>
org.eclipse.emf.databinding.internal; version="0.0.0" <org.eclipse.emf.databinding_1.3.0.v20160208-0841 [315]>
org.eclipse.emf.ecore; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.change; version="0.0.0" <org.eclipse.emf.ecore.change_2.11.0.v20160208-0816 [319]>
org.eclipse.emf.ecore.change.impl; version="0.0.0" <org.eclipse.emf.ecore.change_2.11.0.v20160208-0816 [319]>
org.eclipse.emf.ecore.change.util; version="0.0.0" <org.eclipse.emf.ecore.change_2.11.0.v20160208-0816 [319]>
org.eclipse.emf.ecore.impl; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.plugin; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.provider; version="0.0.0" <org.eclipse.emf.ecore.edit_2.9.0.v20160208-0841 [321]>
org.eclipse.emf.ecore.resource; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.resource.impl; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.util; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xmi; version="0.0.0" <org.eclipse.emf.ecore.xmi_2.11.1.v20160208-0816 [329]>
org.eclipse.emf.ecore.xmi.impl; version="0.0.0" <org.eclipse.emf.ecore.xmi_2.11.1.v20160208-0816 [329]>
org.eclipse.emf.ecore.xmi.util; version="0.0.0" <org.eclipse.emf.ecore.xmi_2.11.1.v20160208-0816 [329]>
org.eclipse.emf.ecore.xml.namespace; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.namespace.impl; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.namespace.util; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.type; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.type.impl; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.type.internal; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecore.xml.type.util; version="0.0.0" <org.eclipse.emf.ecore_2.11.2.v20160208-0816 [318]>
org.eclipse.emf.ecp.common.spi; version="1.8.0" <org.eclipse.emf.ecp.common_1.8.0.20160216-1319 [341]>
org.eclipse.emf.ecp.common.spi.asserts; version="1.8.0" <org.eclipse.emf.ecp.common_1.8.0.20160216-1319 [341]>
org.eclipse.emf.ecp.common.spi.cachetree; version="1.8.0" <org.eclipse.emf.ecp.common_1.8.0.20160216-1319 [341]>
org.eclipse.emf.ecp.internal.view.template.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.ui.view; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.ui.view.swt; version="1.8.0" <org.eclipse.emf.ecp.ui.view.swt_1.8.0.20160216-1319 [367]>
org.eclipse.emf.ecp.view.internal.context; version="1.8.0" <org.eclipse.emf.ecp.view.context_1.8.0.20160216-1319 [377]>
org.eclipse.emf.ecp.view.internal.core.swt; version="1.8.0" <org.eclipse.emf.ecp.view.core.swt_1.8.0.20160216-1319 [380]>
org.eclipse.emf.ecp.view.internal.core.swt.renderer; version="1.8.0" <org.eclipse.emf.ecp.view.core.swt_1.8.0.20160216-1319 [380]>
org.eclipse.emf.ecp.view.internal.model.common; version="1.8.0" <org.eclipse.emf.ecp.view.model.common_1.8.0.20160216-1319 [400]>
org.eclipse.emf.ecp.view.internal.provider; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.view.internal.swt; version="1.8.0" <org.eclipse.emf.ecp.ui.view.swt_1.8.0.20160216-1319 [367]>
org.eclipse.emf.ecp.view.internal.ui; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.view.model.common; version="1.8.0" <org.eclipse.emf.ecp.view.model.common_1.8.0.20160216-1319 [400]>
org.eclipse.emf.ecp.view.model.common.edit.provider; version="1.8.0" <org.eclipse.emf.ecp.view.model.common_1.8.0.20160216-1319 [400]>
org.eclipse.emf.ecp.view.model.internal.reporting; version="1.8.0" <org.eclipse.emf.ecp.view.model_1.8.0.20160216-1319 [399]>
org.eclipse.emf.ecp.view.spi.context; version="1.8.0" <org.eclipse.emf.ecp.view.context_1.8.0.20160216-1319 [377]>
org.eclipse.emf.ecp.view.spi.core.swt; version="1.8.0" <org.eclipse.emf.ecp.view.core.swt_1.8.0.20160216-1319 [380]>
org.eclipse.emf.ecp.view.spi.core.swt.renderer; version="1.8.0" <org.eclipse.emf.ecp.view.core.swt_1.8.0.20160216-1319 [380]>
org.eclipse.emf.ecp.view.spi.model; version="1.8.0" <org.eclipse.emf.ecp.view.model_1.8.0.20160216-1319 [399]>
org.eclipse.emf.ecp.view.spi.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.model_1.8.0.20160216-1319 [399]>
org.eclipse.emf.ecp.view.spi.model.reporting; version="1.8.0" <org.eclipse.emf.ecp.view.model_1.8.0.20160216-1319 [399]>
org.eclipse.emf.ecp.view.spi.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.model_1.8.0.20160216-1319 [399]>
org.eclipse.emf.ecp.view.spi.provider; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.view.spi.provider.reporting; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.view.spi.renderer; version="1.8.0" <org.eclipse.emf.ecp.ui.view_1.8.0.20160216-1319 [364]>
org.eclipse.emf.ecp.view.spi.swt; version="1.8.0" <org.eclipse.emf.ecp.ui.view.swt_1.8.0.20160216-1319 [367]>
org.eclipse.emf.ecp.view.spi.swt.layout; version="1.8.0" <org.eclipse.emf.ecp.ui.view.swt_1.8.0.20160216-1319 [367]>
org.eclipse.emf.ecp.view.spi.swt.reporting; version="1.8.0" <org.eclipse.emf.ecp.ui.view.swt_1.8.0.20160216-1319 [367]>
org.eclipse.emf.ecp.view.template.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.domainmodelreference.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.domainmodelreference.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.domainmodelreference.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.viewModelElement.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.viewModelElement.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.selector.viewModelElement.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.alignment.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.alignment.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.alignment.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.background.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.background.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.background.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.fontProperties.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.fontProperties.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.fontProperties.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.mandatory.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.mandatory.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.mandatory.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tab.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tab.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tab.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tableValidation.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tableValidation.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.tableValidation.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.textControlEnablement.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.textControlEnablement.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.textControlEnablement.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.validation.model; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.validation.model.impl; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.ecp.view.template.style.validation.model.util; version="1.8.0" <org.eclipse.emf.ecp.view.template.model_1.8.0.20160216-1319 [423]>
org.eclipse.emf.edit; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.command; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.domain; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.provider; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.provider.resource; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.tree; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.tree.impl; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.tree.provider; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.tree.util; version="0.0.0" <org.eclipse.emf.edit_2.11.1.v20160208-0841 [444]>
org.eclipse.emf.edit.ui; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.action; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.action.emfforms; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emf.edit.ui.celleditor; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.dnd; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.provider; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.util; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emf.edit.ui.view; version="0.0.0" <org.eclipse.emf.edit.ui_2.11.1.v20160208-0841 [445]>
org.eclipse.emfforms.common; version="1.8.0" <org.eclipse.emfforms.common_1.8.0.20160216-1319 [507]>
org.eclipse.emfforms.internal.common.report; version="1.8.0" <org.eclipse.emfforms.common_1.8.0.20160216-1319 [507]>
org.eclipse.emfforms.internal.core.services.controlmapper; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.internal.core.services.editsupport; version="1.8.0" <org.eclipse.emfforms.core.services.editsupport_1.8.0.20160216-1319 [516]>
org.eclipse.emfforms.internal.core.services.mappingprovider; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.internal.core.services.scoped; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.internal.swt.core; version="1.8.0" <org.eclipse.emfforms.swt.core_1.8.0.20160216-1319 [531]>
org.eclipse.emfforms.internal.swt.treemasterdetail; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emfforms.internal.swt.treemasterdetail.defaultprovider; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emfforms.spi.common.locale; version="1.8.0" <org.eclipse.emfforms.common_1.8.0.20160216-1319 [507]>
org.eclipse.emfforms.spi.common.report; version="1.8.0" <org.eclipse.emfforms.common_1.8.0.20160216-1319 [507]>
org.eclipse.emfforms.spi.core.services.controlmapper; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.databinding; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.domainexpander; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.editsupport; version="1.8.0" <org.eclipse.emfforms.core.services.editsupport_1.8.0.20160216-1319 [516]>
org.eclipse.emfforms.spi.core.services.label; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.mappingprovider; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.structuralchange; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.core.services.view; version="1.8.0" <org.eclipse.emfforms.core.services_1.8.0.20160216-1319 [508]>
org.eclipse.emfforms.spi.swt.core; version="1.8.0" <org.eclipse.emfforms.swt.core_1.8.0.20160216-1319 [531]>
org.eclipse.emfforms.spi.swt.core.data; version="1.8.0" <org.eclipse.emfforms.swt.core_1.8.0.20160216-1319 [531]>
org.eclipse.emfforms.spi.swt.core.di; version="1.8.0" <org.eclipse.emfforms.swt.core.di_1.8.0.20160216-1319 [532]>
org.eclipse.emfforms.spi.swt.core.layout; version="1.8.0" <org.eclipse.emfforms.swt.core_1.8.0.20160216-1319 [531]>
org.eclipse.emfforms.spi.swt.treemasterdetail; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emfforms.spi.swt.treemasterdetail.actions; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emfforms.spi.swt.treemasterdetail.actions.delegating; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.emfforms.spi.swt.treemasterdetail.util; version="1.8.0" <org.eclipse.emfforms.swt.treemasterdetail_1.8.0.20160216-1319 [536]>
org.eclipse.equinox.app; version="1.1.0" <org.eclipse.equinox.app_1.3.300.v20150423-1356 [544]>
org.eclipse.equinox.events; version="1.0.0" <org.eclipse.equinox.common_3.7.0.v20150402-1709 [546]>
org.eclipse.equinox.internal.app; version="0.0.0" <org.eclipse.equinox.app_1.3.300.v20150423-1356 [544]>
org.eclipse.equinox.log; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.jface; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.action; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.action.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.bindings; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.bindings.keys; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.bindings.keys.formatting; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.commands; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.contexts; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.databinding.dialog; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.fieldassist; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.preference; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.swt; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.util; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.viewers; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.databinding.wizard; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.dialogs; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.dialogs.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.fieldassist; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.fieldassist.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.internal; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.internal.databinding.provisional.swt; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.internal.databinding.provisional.viewers; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.internal.databinding.swt; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.internal.databinding.util; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.internal.databinding.viewers; version="0.0.0" <org.eclipse.jface.databinding_1.7.0.v20150406-2148 [670]>
org.eclipse.jface.internal.provisional.action; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.layout; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.menus; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.operation; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.preference; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.preference.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.resource; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.util; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.viewers; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.viewers.deferred; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.window; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.wizard; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.jface.wizard.images; version="0.0.0" <org.eclipse.jface_3.11.1.v20160128-1644 [669]>
org.eclipse.osgi.container; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.container.builders; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.container.namespaces; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.framework.console; version="1.1.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.framework.eventmgr; version="1.2.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.framework.internal.reliablefile; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.framework.log; version="1.1.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.framework.util; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.debug; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.framework; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.hookregistry; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.loader; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.loader.buddy; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.loader.classpath; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.loader.sources; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.location; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.messages; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.provisional.service.security; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.provisional.verifier; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.service.security; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.serviceregistry; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.signedcontent; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.internal.url; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.launch; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.report.resolution; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.datalocation; version="1.3.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.debug; version="1.2.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.environment; version="1.3.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.localization; version="1.1.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.pluginconversion; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.resolver; version="1.6.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.runnable; version="1.1.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.security; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.service.urlconversion; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.signedcontent; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.storage; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.storage.bundlefile; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.storage.url.reference; version="0.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.storagemanager; version="1.0.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.osgi.util; version="1.1.0" <org.eclipse.osgi_3.10.102.v20160118-1700 [0]>
org.eclipse.swt; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.accessibility; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.awt; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.browser; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.custom; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.dnd; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.events; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.graphics; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.gdip; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.image; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.mozilla; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.ole.win32; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.opengl.win32; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.theme; version="0.0.0" <org.eclipse.swt_3.104.2.v20160212-1350 [930]>
org.eclipse.swt.internal.win32; version="0.0.0"
Re: [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1726310 is a reply to message #1726208] Fri, 11 March 2016 04:47 Go to previous messageGo to next message
the bundle containing the ecore editor is called org.eclipse.emfforms.editor.ecore
As far as I can see this is missing in your IDE. Are you sure the installation was successful? Did you check the error log?
I also tried installing the EMFForms SDK + the Editor Feature to a DSL Eclipse and with these feature it is working as well.
Cheers
Re: [EMF Forms] New Ecore Editor Reloaded not showing up in Mars.2 [message #1727187 is a reply to message #1726310] Mon, 21 March 2016 03:26 Go to previous message
I got it working.... I just added the feature to our oomph setup and
created a new IDE ...all is fine now!
Thanks for your help!
Oliver
Am 11.03.2016 um 10:47 schrieb Johannes Faltermeier:
> Hi, the bundle containing the ecore editor is called
> Cheers
Previous Topic:[EEF] NullPointerException when trying to initialize EEF models
Next Topic:[EMF Forms] Table Control : Column Width
Current Time: Thu Sep 25 09:24:53 EDT 2025
Powered by FUDForum. Page generated in 0.05449 seconds
