Error with "platform:/plugin" scheme URI usage [message #1725904] |
Tue, 08 March 2016 07:34  |
Hi All,
I am using Mars.1 Release (4.5.1) and facing issue with "platform" scheme URI usage. I have all my resources (images) in a separate resource plug-in/bundle and I am using those resources in all other plug-ins using "icon" attribute of the extension point. I am not able to access the image and get a red square instead. It was working fine when I was using Eclipse Kepler and after moving to Mars.1, I face this issue.
Another observation is that when I place the resource (image) under the same plugin and directly provide the resource name like "icon=button.png" then it works fine. Problem is with accessing resources from other plugins. I am facing this issue with "icon" attribute in Views (org.eclipse.ui.views extension) also.
Any help in solving this issue is very much appreciated. Here is description of my issue:
My resource plugin identifier (Bundle-SymbolicName) is: com.prd.myapp.resource
My image is placed under the folder: com/prd/myapp/resource/image
My image is: button.png
I am accessing this resource from another plugin using extension "icon" attribute as below:
<extension
point="org.eclipse.ui.editors">
<editor
class="com.prd...EditorClass"
default="true"
extensions="myprd"
icon="platform:/plugin/com.prd.myapp.resource/com/prd/myapp/resource/image/button.png"
id="com.prd.."
name="mylabel">
</editor>
</extension>
Thank you.
- Vivek veera
FUDForum. Page generated in 0.02959 seconds
