Home » Modeling » TMF (Xtext) » Regarding ignoreCase for Keywords.
Regarding ignoreCase for Keywords. [message #1725837] Tue, 08 March 2016 04:39 Go to next message
pranay roy is currently offline pranay royFriend
I wish to add a property to ignore case for keywords in my grammar.
I tried the example mentioned in
http://stackoverflow.com/questions/30889847/match-string-in-xtext-regardless-of-upper-lower-case
I updated the mwe2 configuration and I found out that
org.eclipse.xtext.generator.parser.antlr.ex.rt.AntlrGeneratorFragment could not be found.
I am using XText 2.9.0 . I checked the configuration property and found similar classes with suffix 2.
fragment = parser.antlr.XtextAntlrGeneratorFragment2 {}
fragment = ui.contentAssist.ContentAssistFragment2 {}
I tried to used ignoreCase =true property with the above but "ignoreCase"property could not be identified.
Please suggest .
[Updated on: Tue, 08 March 2016 04:40]
Report message to a moderator
Re: Regarding ignoreCase [message #1725839 is a reply to message #1725837] Tue, 08 March 2016 04:52 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
You can use
parserGenerator = {
options = {
ignoreCase=true
Twitter : @chrdietrich
Re: Regarding ignoreCase [message #1725840 is a reply to message #1725839] Tue, 08 March 2016 05:08 Go to previous messageGo to next message
This is my mwe2 file. Should the snippet you suggest be added using the Fragment2 or any specific place below.
module org.xtext.example.mydsl.GenerateEinDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "ein-suggestions-dsl-core"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				ideaPlugin = {
					enabled = false
				web = {
					enabled = false
				genericIde = {
                                enabled = true
                                name = "ein-suggestions-dsl-core-ide"
             mavenLayout = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.example.mydsl.EinDsl"
			fileExtensions = "eindsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Re: Regarding ignoreCase [message #1725841 is a reply to message #1725840] Tue, 08 March 2016 05:14 Go to previous messageGo to next message
Inside language (in eclipse you have content assist and validation for
mwe2)
Re: Regarding ignoreCase [message #1725842 is a reply to message #1725840] Tue, 08 March 2016 05:16 Go to previous messageGo to next message
I got it
Re: Regarding ignoreCase [message #1725844 is a reply to message #1725842] Tue, 08 March 2016 06:06 Go to previous messageGo to next message
When I add the above in mwe2 .There is a build error in the application .
This import cannot be resolved to a type.
import org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslLexer;
When I remove the ignoreCase addition from mwe2 file it builds fine. I am thinking what could be the reason
Re: Regarding ignoreCase [message #1725846 is a reply to message #1725844] Tue, 08 March 2016 06:12 Go to previous messageGo to next message
du you have any exceptions in the mwe log?
maybe you have some upper lower case ambiguities in your grammar
Re: Regarding ignoreCase [message #1725848 is a reply to message #1725846] Tue, 08 March 2016 06:21 Go to previous messageGo to next message
Hi ,
I do not get any exceptions in the mwe2 log. I do get some warnings related to uppercase / lowercase ambiguity.Something like
"Decision can match input such as "By Month" using multiple alternatives: 1, 2"
my keywords are "by" and "month"
Could that be an issue? How can I resolve it?
Re: Regarding ignoreCase [message #1725849 is a reply to message #1725848] Tue, 08 March 2016 06:22 Go to previous messageGo to next message
no that should not be an issue. can you share the grammar that causes the problem?
Re: Regarding ignoreCase [message #1725850 is a reply to message #1725849] Tue, 08 March 2016 06:28 Go to previous messageGo to next message
http://pastebin.com/RtwFg8p6
Re: Regarding ignoreCase [message #1725851 is a reply to message #1725850] Tue, 08 March 2016 06:31 Go to previous messageGo to next message
i cannot reproduce this using xtext 2.9.2.
are you sure there is nothing generated in /org.xtext.example.mydsl.ide/src/main/xtext-gen/org/xtext/example/mydsl/ide/contentassist/antlr/lexer
Re: Regarding ignoreCase [message #1725854 is a reply to message #1725851] Tue, 08 March 2016 06:49 Go to previous messageGo to next message
No ,I dont see it generated after.
before
index.php/fa/25215/0/
after
index.php/fa/25216/0/
[Updated on: Tue, 08 March 2016 06:49]
Re: Regarding ignoreCase [message #1725855 is a reply to message #1725854] Tue, 08 March 2016 06:51 Go to previous messageGo to next message
how do you run the generation?
Re: Regarding ignoreCase [message #1725856 is a reply to message #1725855] Tue, 08 March 2016 06:53 Go to previous messageGo to next message
and did you test that with xtext 2.9.2
Re: Regarding ignoreCase [message #1725857 is a reply to message #1725855] Tue, 08 March 2016 06:53 Go to previous messageGo to next message
I just clean install the project.
Re: Regarding ignoreCase [message #1725858 is a reply to message #1725856] Tue, 08 March 2016 06:57 Go to previous messageGo to next message
I just checked with 2.9.2 . Its the same. Sad
Re: Regarding ignoreCase [message #1725860 is a reply to message #1725858] Tue, 08 March 2016 06:59 Go to previous messageGo to next message
My mwe2 file.
var rootPath = ".."
Workflow {
		configuration = {
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				ideaPlugin = {
					enabled = false
				web = {
					enabled = false
				genericIde = {
                                enabled = true
             mavenLayout = true
			code = {
				encoding = "UTF-8"
			serializer = {
			validator = {
			parserGenerator = {
                        options = {
                        ignoreCase=true
Re: Regarding ignoreCase [message #1725861 is a reply to message #1725860] Tue, 08 March 2016 07:01 Go to previous messageGo to next message
can you share a complete project
Re: Regarding ignoreCase [message #1725867 is a reply to message #1725861] Tue, 08 March 2016 07:24 Go to previous messageGo to next message
update the version
Re: Regarding ignoreCase [message #1725871 is a reply to message #1725867] Tue, 08 March 2016 07:46 Go to previous messageGo to next message
the project you shared is completely mess up. please try a new one and zip the parent only
Re: Regarding ignoreCase [message #1725872 is a reply to message #1725871] Tue, 08 March 2016 07:48 Go to previous messageGo to next message
You can remove the parent definition and add the xtext version . is there any other error.
Re: Regarding ignoreCase [message #1725873 is a reply to message #1725872] Tue, 08 March 2016 08:14 Go to previous messageGo to next message
please share something i can simply run
Re: Regarding ignoreCase [message #1726010 is a reply to message #1725873] Wed, 09 March 2016 03:56 Go to previous messageGo to next message
I have resolved the issues. Please have a look at the attached project
Re: Regarding ignoreCase [message #1726012 is a reply to message #1726010] Wed, 09 March 2016 04:15 Go to previous messageGo to next message
I have another observation from this. I see that the content assist does not does not suggest full keywords on partial text except "plot"
When I type p i get "plot". while for other keywords I dont get the content assist. Example.:
"plot abc fo" doesn't suggest "plot comm for". Same thing for all keywords except plot(which is the first word).
Moreover, I get content assist for average as well.
"prefix" :"plot a"
gives me "plot average"
but
"prefix" "plot average f" does not show "plot average for"
Am I missing something?
[Updated on: Wed, 09 March 2016 04:26]
Re: Regarding ignoreCase [message #1726014 is a reply to message #1726012] Wed, 09 March 2016 04:47 Go to previous messageGo to next message
plot average for is not valid in your grammar since (measure=MeasureList) requires at least one measurelist
Re: Regarding ignoreCase [message #1726015 is a reply to message #1726014] Wed, 09 March 2016 05:04 Go to previous messageGo to next message
p.s:
besides this: use the debugger !!!!
this would have shown you that the contexts get lost and how you can workaround it
	override def Iterable<ContentAssistContext> getFilteredContexts(Collection<ContentAssistContext> contexts) {
		return contexts
please file a bug
Re: Regarding ignoreCase [message #1726016 is a reply to message #1726014] Wed, 09 March 2016 05:30 Go to previous messageGo to next message
I am sorry i missed a measure list
so "plot average profit f" does not show me "for"
Re: Regarding ignoreCase [message #1726017 is a reply to message #1726016] Wed, 09 March 2016 05:33 Go to previous messageGo to next message
As I said this is a bug imho please file a ticket and use my workaround
Re: Regarding ignoreCase [message #1726019 is a reply to message #1726017] Wed, 09 March 2016 05:57 Go to previous messageGo to next message
Ok Thank. with your workaround , please let me know how
"plot profit fo" suggests me "and" after fo instead of "for" .
I also observe that in all the four contexts for this case ,measure name is considered as "profit fo" . while there is a possibility of "for" coming from "fo" .
How can I filter the contexts appropriately in this case?
SO the bug is with the other issue i.e lowerCase setting ?
Re: Regarding ignoreCase [message #1726024 is a reply to message #1726019] Wed, 09 March 2016 06:17 Go to previous messageGo to next message
no it is a separater issue.
i cannot help you with the workaround sry
Re: Regarding ignoreCase [message #1726027 is a reply to message #1726024] Wed, 09 March 2016 06:56 Go to previous messageGo to next message
So, how can i resolve the lowercase setting issue .what is the bug I am confused
Re: Regarding ignoreCase [message #1726028 is a reply to message #1726027] Wed, 09 March 2016 07:01 Go to previous messageGo to next message
hi the two Things have NOTHING todo with each other
bug is: i dot get proposals for the f
i already told you how to get ignorecase keywords
[Updated on: Wed, 09 March 2016 07:02]
Re: Regarding ignoreCase [message #1726036 is a reply to message #1726028] Wed, 09 March 2016 08:01 Go to previous messageGo to next message
Yeah you mentioned to solve the ignore case using this
parserGenerator = {
options = {
ignoreCase=true
This seems to give an error as the lexer is not created.
I shared my project that you can directly build and run.
Attachment name is : ein-suggestions-dsl 2.zip
Re: Regarding ignoreCase [message #1726039 is a reply to message #1726036] Wed, 09 March 2016 08:32 Go to previous messageGo to next message
but mvn clean install works fine for me
Re: Regarding ignoreCase [message #1726057 is a reply to message #1726039] Wed, 09 March 2016 10:17 Go to previous messageGo to next message
Do you have some text before "but"?. Are you able to replicate the issue I am having.
Re: Regarding ignoreCase [message #1726058 is a reply to message #1726057] Wed, 09 March 2016 10:21 Go to previous messageGo to next message
no i am not. that is the problem.
mvn clean install on the parent works fine
Re: Regarding ignoreCase [message #1726059 is a reply to message #1726057] Wed, 09 March 2016 10:26 Go to previous messageGo to next message
raised the bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=489272
Re: Regarding ignoreCase [message #1726060 is a reply to message #1726059] Wed, 09 March 2016 10:28 Go to previous messageGo to next message
I have not added this in the mwe2 file
parserGenerator = {
options = {
ignoreCase=true
please add this to replicate the issue
[Updated on: Wed, 09 March 2016 10:28]
Re: Regarding ignoreCase [message #1726061 is a reply to message #1726060] Wed, 09 March 2016 10:30 Go to previous messageGo to next message
no it is added the the version2 zip
Re: Regarding ignoreCase [message #1726149 is a reply to message #1726061] Thu, 10 March 2016 07:48 Go to previous messageGo to next message
Thanks Christian for your help on this. I found out that the file was created in the lexer folder (which is at the same level as internal ) .Previously the lexer was in internal folder. Thats why my imports were breaking.
Thanks much Smile
Re: Regarding ignoreCase [message #1726457 is a reply to message #1726149] Mon, 14 March 2016 06:35 Go to previous messageGo to next message
I have another issue regarding Keywords.
I have this statement for the grammar understand . "plot active days" . I see that there are no contexts generated.Hence I do not get any content assist proposal . I have "day" in grammar. But, in my statement I expect "active days" to be identified as measure as its a multiword as defined by my grammar.
Re: Regarding ignoreCase [message #1726459 is a reply to message #1726457] Mon, 14 March 2016 06:44 Go to previous messageGo to next message
?!? please open a new ticket and provide all needed. as i said before the current Content assist impl Kind a sucks. you should use the DEBUGGER to find out what happens.
and a unit test to find out how your stuff is actually parsed.
if days is a keyword it may not be parsed as an ID and thus not as a measure.
you may introduce a datatype rule like
MYID : ID | 'days' | 'otherkeyword' | ....;
but thgis may turn your already ambigous grammar into an ambiguity nightmare
Re: Regarding ignoreCase [message #1726462 is a reply to message #1726459] Mon, 14 March 2016 06:56 Go to previous messageGo to next message
Hi ,
I have debugged and added the unit test which fails . I see that "plot active days" has "active" as the "measure" name . Is the the expected behaviour .As I understand ,it should include "days" as well. What is the ideal way to resolve this issue. Thanks
Re: Regarding ignoreCase [message #1726463 is a reply to message #1726462] Mon, 14 March 2016 06:58 Go to previous messageGo to next message
hi i answered both of your questions.
please share the grammar and the unit test
Re: Regarding ignoreCase [message #1726465 is a reply to message #1726463] Mon, 14 March 2016 07:22 Go to previous messageGo to next message
Test
	@Test
	def void testPlotMeasureWithDays() {
		val query ="plot active days"
		val result = parseHelper.parse(query)
		var expected =Arrays.asList("active days")
		Assert.assertEquals(result.getQkeyWord,"plot")
		Assert.assertEquals(expected,result.getMeasureList)
Grammar
http://pastebin.com/5irzNHKX
Re: Regarding ignoreCase [message #1726467 is a reply to message #1726465] Mon, 14 March 2016 07:39 Go to previous messageGo to next message
Assert.assertEquals("Found erros: " + result.eResource.errors.map[message].join(", "),0, result.eResource.errors.size)
a possible solutioin is to introduce a datatype rule
MyID: ID | 'days'| ... and use that in Measure. (might be ambigous)
or simply escape the keyword using ^days
Re: Regarding ignoreCase [message #1726476 is a reply to message #1726467] Mon, 14 March 2016 09:11 Go to previous messageGo to next message
Thanks ."or simply escape the keyword using ^days " Please elaborate on this.
Re: Regarding ignoreCase [message #1726515 is a reply to message #1726476] Mon, 14 March 2016 11:42 Go to previous messageGo to next message
if you use proper value converters in xtext you can Workaround the keyword is not an ID Problem like this
Hello noKeyword!
Hello ^Hello!
Re: Regarding ignoreCase [message #1726523 is a reply to message #1726515] Mon, 14 March 2016 12:19 Go to previous messageGo to next message
I am sorry your sentence doesnt seem to be complete " you can Workaround the keyword is not an ID Problem like this" Should ^ appear in grammar or statement (plot..)
[Updated on: Mon, 14 March 2016 12:20]
Re: Regarding ignoreCase [message #1726524 is a reply to message #1726523] Mon, 14 March 2016 12:23 Go to previous messageGo to next message
No
by Default it is the grammar (ID) and IDValueCOnverter strips it off and adds it when serializing.
so you can either do the same for your stuff.
your you have to Switch from ID to MyID
Re: Regarding ignoreCase [message #1726525 is a reply to message #1726524] Mon, 14 March 2016 12:24 Go to previous messageGo to next message
both
Hello noKeyword!
Hello ^Hello!
are actual models
Re: Regarding ignoreCase [message #1726604 is a reply to message #1726523] Tue, 15 March 2016 02:58 Go to previous messageGo to next message
you meant,Switch from MyID to ID right?
Re: Regarding ignoreCase [message #1726605 is a reply to message #1726604] Tue, 15 March 2016 04:17 Go to previous messageGo to next message
No the other way round.
Greeting : 'Hello' name=MyID '!';
MyID: ID|'Hello';
Hello Hello!
Or use the escaping
Greeting : 'Hello' name=ID '!';
Hello ^Hello!
[Updated on: Tue, 15 March 2016 04:29]
Re: Regarding ignoreCase [message #1727449 is a reply to message #1726605] Wed, 23 March 2016 08:40 Go to previous messageGo to next message
Thanks for the reply.
How can I add multi words? . Instead of Hello i have a list of words that should be included.Can I add another Category called "KEYWORDS" and have it included here as (Hello). Does it add additional performance overhead.?
Could you give an example please.
MyID: ID|'Hello';
[Updated on: Wed, 23 March 2016 08:41]
Re: Regarding ignoreCase [message #1727451 is a reply to message #1727449] Wed, 23 March 2016 08:45 Go to previous messageGo to next message
guess what:
MyID : ID | "keyword1" | .... | "keywordn";
Re: Regarding ignoreCase [message #1727452 is a reply to message #1727449] Wed, 23 March 2016 08:48 Go to previous messageGo to next message
I have just added
KEYWORDS:
('total'|'days')
and
^KEYWORDS to my definition of ID
Re: Regarding ignoreCase [message #1727455 is a reply to message #1727452] Wed, 23 March 2016 08:55 Go to previous messageGo to next message
Re: Regarding ignoreCase [message #1727462 is a reply to message #1727455] Wed, 23 March 2016 09:21 Go to previous messageGo to next message
MyString:ID |SPECIAL|^KEYWORDS;
SPECIAL:
	('/' | ';' | ',' | '!' | '§' | '%' | '&' | '(' | ')' | '?' | '*' | '+' | '.' | '-' | '|' | '[' | ']' | '#' | '@' |'{'|'}' |'$' |'^' |'~' |INT |':');
KEYWORDS:
	('total'|'days'|'weeks')
I start getting multiple warning messages when I build.
: Decision can match input such as "Total Asterisk" using multiple alternatives: 1, 2
I know its an ambiguity issue. Is there a better solution than this. My keywords could be more.
Re: Regarding ignoreCase [message #1727464 is a reply to message #1727462] Wed, 23 March 2016 09:35 Go to previous messageGo to next message
but why ^KEYWORDS. KEYWORDS should be fine.
[Updated on: Wed, 23 March 2016 09:37]
Re: Regarding ignoreCase [message #1727467 is a reply to message #1727464] Wed, 23 March 2016 09:39 Go to previous messageGo to next message
Yeah , I am sorry . it should be without ^. I am trying to find a better way to solve this issue.
Re: Regarding ignoreCase [message #1727469 is a reply to message #1727467] Wed, 23 March 2016 09:48 Go to previous messageGo to next message
what i still dont get. how do you want to deal with the ambiguity
Re: Regarding ignoreCase [message #1729912 is a reply to message #1727469] Wed, 20 April 2016 08:57 Go to previous message
This is an example of using KEYWORDS
This is my grammar
http://pastebin.com/G0VTGyMj
This test fails.
@Test
	def void testPlotMeasureByTime() {
		val query ="plot profit by month"
		var expected =Arrays.asList("profit")
		var groupBy=result.getGroupBy
		var timeDimension=getTimeDimension(groupBy)
		Assert.assertEquals(timeDimension,"month")
While this passes.
	@Test
	def void testPlotMeasureByDimensionByTime() {
		val query ="plot profit by country by month"
		var dimension =getDimension(groupBy)
		Assert.assertEquals(dimension,"country")
Util Methods.
	def String getTimeDimension(EList<Group> groups){
		return groups.get(0).getTimeGroup.get(0).getTimeGroup
	def String getQkeyWord(Model result){
		return result.greetings.key.getQKeyword
	def List<String> getMeasureList(Model result){
		return result.greetings.measure.names.toList
I have some ambiguities in my grammar as well. I would like to understand why month is taken as timeDimension in one test while the other test fails and considers it as dimGroup
Any suggestion will be highly appreciated.
Previous Topic:Invoke a Rule Explicitly
Next Topic:definition terminal STRING
Current Time: Fri Apr 26 20:27:01 GMT 2024
Powered by FUDForum. Page generated in 0.07133 seconds
