Profile is not current and update problems [message #1725207] |
Tue, 01 March 2016 11:51 |
We are experiencing strange behaviour with out Eclipse 4.5-based product when it comes to updating and installing extension. If the product starts and you check for updates, none are found, although there are some available. If you go to Help->About->Installation Details->Installed Software, the tab is completely empty, which explains why no updates are found. Then if you try to install the update via Install new software and error message pops up, saying the the profile is not current ("expected timestamp 0, actual is 0"). If you go back in the wizard and retry again, the update/installation works and after that also the installed software tab shows the expected contents. Any ideas what's wrong here? I tried to debug the profile handling code a bit (the one that throws the strange error message), but didn't get any further.
FUDForum. Page generated in 0.03644 seconds
