Undertow vs tomcat vs jetty [message #1724835] |
Fri, 26 February 2016 12:37 |
Nagavijay Sivakumar Messages: 11 Registered: August 2015 |
Undertow is lightweight flexible performant web server written in java, providing both blocking and non-blocking API's based on NIO.
High Performance:
Here are few links which shows performance benchmarks.
http:==bayou.io/draft/Comparing_Java_HTTP_Servers_Latencies.html
http:==blog.arungupta.me/undertow-benchmarks-wildfly/
Some of high level Features:
Servlet 3.1
Embeddable
Flexible
non-blocking IO
Its possible to do Datasource configuration
https:==docs.jboss.org/author/display/WFLY8/DataSource+configuration?_sscc=t
Spring Easy integration:
https:==docs.spring.io/spring-boot/docs/current/reference/html/howto-embedded-servlet-containers.html#howto-use-undertow-instead-of-tomcat
What are the other things to consider inorder to migrate Vorto repository and Vorto generators from tomcat to undertow?
Any comments/Feedback?
(Please Note: Replace : == to // in the urls. Because the site doesn't allow to post the urls.)
[Updated on: Fri, 26 February 2016 12:38] Report message to a moderator
FUDForum. Page generated in 0.03577 seconds
