Home » Language IDEs » AspectJ » Why is weaving in aspects from another project not working?
Why is weaving in aspects from another project not working? [message #33295] |
Thu, 15 April 2004 16:08 |
Originally posted by: nedim.codemonkeys.org
I asked similar question couple of weeks ago but got no response. So let
me rephrase it.
When weaving in aspects from another project I have to compile and jar
that other project and specify it in "Project Properties->AspectJ->Input
jars (aspects)", even though I have both projects in my Eclipse workspace.
Why is it not possible to just use aspects from that other projects if
project dependency is properly set?
This is really pain it the behind and limits the usability of AJDT a
great deal. I can't think of but simplest work that would all be
contained in single Eclipse project.
Thanks.
Re: Why is weaving in aspects from another project not working? [message #33409 is a reply to message #33295] |
Thu, 15 April 2004 19:32 |
Originally posted by: clemas.uk.ibm.com
With the current codebase (up to AJDT 1.1.7) - the way to achieve what you
want to do is using Eclipse Linked Source Folders. Suppose you have
Project A which is pure Java and Project B that is AspectJ. You want to
apply your aspects from Project B to Project A. You open the
ProjectProperties for Project B and add a new source folder (through the
java build path tab). When you add the source folder, make it a linked
source folder that points to the source folder for ProjectA.
When setup this, ProjectA can build as a pure java project. When you
build ProjectB it will apply your aspects to the source from ProjectA and
the resulting output will be put into the bin directory for ProjectB.
The Lancaster codebase, with its tighter integration with Eclipse, will
work in a much more seamless fashion.
Andy.
Andy Clement
AJDT Development
Re: Why is weaving in aspects from another project not working? [message #40456 is a reply to message #33409] |
Mon, 30 August 2004 22:04 |
Originally posted by: k.b.com
Andy Clement wrote:
> Andy.
> Andy Clement
> AJDT Development
I am working in WSAD, which is based on 2.x eclipse, and do not see a
way to use the linked folder concept. Any ideas on how I might get
things working? We have multiple projects in a very complex overall
project, and I am trying to use aspects to aid in testing / mocking, etc.
Thanks in advance,
Keith Lancaster
Re: Why is weaving in aspects from another project not working? [message #40487 is a reply to message #40456] |
Tue, 31 August 2004 16:43 |
Originally posted by: mchapman.uk.ibm.com
On Mon, 30 Aug 2004 17:04:23 -0500, Keith wrote:
> I am working in WSAD, which is based on 2.x eclipse, and do not see a way
> to use the linked folder concept. Any ideas on how I might get things
> working? We have multiple projects in a very complex overall project, and
Hi Keith,
This was answered a while ago on the aspectj-users mailing list. Below is
a cut and paste.
Matt.
---snip---
Re: [aspectj-users] AJDT - cross-project weaving in WSAD
* From: Adrian Powell <aspectj-users@xxxxxxxxxxxxxxxx>
* Date: Thu, 29 Jul 2004 09:38:05 -0700
* Delivered-to: aspectj-users@eclipse.org
Jean-Luc,
WSAD disables linking by default, so if you wish to use these
instructions, you will first need to enable linking (Window >
Preferences > Workbench > Linked Resources > Enable linked resources).
cheers,
-adrian.
---snip---
Re: Why is weaving in aspects from another project not working? [message #582972 is a reply to message #33409] |
Keith Messages: 7 Registered: July 2009 |
Andy Clement wrote:
> Andy.
> Andy Clement
> AJDT Development
Thanks in advance,
Keith Lancaster
Re: Why is weaving in aspects from another project not working? [message #582996 is a reply to message #40456] |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Keith,
a cut and paste.
Matt.
---snip---
Jean-Luc,
cheers,
-adrian.
---snip---
Current Time: Tue Sep 24 23:31:54 GMT 2024
Powered by FUDForum. Page generated in 0.04953 seconds
