Home » Eclipse Projects » e(fx)clipse » is it possible to use eclipse service in controller of fxml?
is it possible to use eclipse service in controller of fxml? [message #1724147] Sun, 21 February 2016 18:21 Go to next message
Milankumar Ardeshana is currently offline Milankumar ArdeshanaFriend
hi
for my application i am loading ui from fxml. i have multiple part application. and each part is as below
Part1                                                   | Part2
personabstractpart.java (part)                          | PersonDetailedInfoPart.java (part)
personabstractpart.fxml (ui-> built using javafx 8)     | PersonDetailedInfoPart.fxml (ui-> built using javafx 8)
personabstractpartcontroller.java (controller for fxml) | PersonDetailedInfoPartcontroller.java (controller for fxml)
now i want to use ESelectionService in my controller class. as below
@FXML
private TableView<Person> personTable;
@Inject
private ESelectionService selectionService;
@FXML
private void initialize() {
    	personTable.getSelectionModel().selectedItemProperty().addListener(new ChangeListener<Person>() {
			public void changed(ObservableValue<? extends Person> observable, Person oldValue, Person newValue) {
				selectionService.setSelection(newValue);
				System.out.println("set: " + newValue);
my controller class is not able to inject selection service here.
Question is
(a) is it possible to inject selectionService/controllerclass using ContextInjectionFactory? i don't know what(controller/service) i should inject and where(view/controller) i should inject and is it recommended?
(b) (i) so what currently i am doing is loading fxml and after that i am fetching my controlls from root of fxml and adding listener to my tableview. is this recommended?
root = FXMLLoader.load(PersonAbstractPart.class.getResource("PersonAbstractPart.fxml"));
AnchorPane box=(AnchorPane)root;
parent.setTop(box);
Node splitpane = box.getChildren().get(0);
SplitPane spnode = (SplitPane)splitpane;
Node anchornode = spnode.getItems().get(0);
AnchorPane anchorPane = (AnchorPane)anchornode;
personTable=(TableView<Person>)anchorPane.getChildren().get(0);
(ii) can i make my view to be controller? --> in view class @FXML is not fetching the controls after loading the fxml. and can't use easily as i can use in controller class.
any help appreciated.
Milan
Re: is it possible to use eclipse service in controller of fxml? [message #1724149 is a reply to message #1724147] Sun, 21 February 2016 19:48 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
https://wiki.eclipse.org/Efxclipse/Runtime/Recipes#.40FXMLLoader
Tom
On 21.02.16 19:21, Milankumar Ardeshana wrote:
> hi
> Part1 | Part2
> (part)
> @FXML
> @Inject
> @FXML
> @Override
> System.out.println("set: " + newValue); }
Re: is it possible to use eclipse service in controller of fxml? [message #1724150 is a reply to message #1724149] Sun, 21 February 2016 20:50 Go to previous message
Perfect. Thanks.
Previous Topic:Buckminster can't resolve org.eclipse.fx.javafx
Next Topic:opening a ui modeled dialogue from main thread leads to exception
Current Time: Fri Apr 26 14:45:44 GMT 2024
Powered by FUDForum. Page generated in 0.03707 seconds
