| Reload Editor from different EditorInput for Save As [message #1722714] |
Mon, 08 February 2016 09:07  |
Hello
I am trying to implement a "save as" function for my Graphiti editor. It should save the current diagram to a new file and the editor should have the input from the new file as its editorInput. Saving to a new file is not a problem but I don't manage to have the new File open in the editor instead of the old one.
What I do at the moment is this: In the doSaveAs() method of my custom DiagramEditor I first save the diagram to a new file. Then I create a new DiagramEditorInput with the URI from the new file and the provider id from the old editorInput like this:
DiagramEditorInput newInput = new DiagramEditorInput(fileUri, input.getProviderId());
After that i want to reload the editor with the new input. What I tried is:
But this causes the NullpointerException attached below. Seems like a new ConfigurationProvider is created but the ContextButtonManager is not set.
My question now is: Am I simply doing it wrong, is this a bug or is it just not intended to set a new DiagramEditorInput?
Is there a better way for implementing my "save as" functionality? The workaround would of course be to completely close the editor and reopen it for the new file, but it seems to me that it would be nicer to simply reload the content.
Would be great if someone could point me in the right direction.
Thomas
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.activate(ShapeEditPart.java:129)
at org.eclipse.gef.editparts.AbstractEditPart.activate(AbstractEditPart.java:160)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate(AbstractGraphicalEditPart.java:195)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.activate(ShapeEditPart.java:127)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:215)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.graphiti.ui.editor.DiagramBehavior.initializeGraphicalViewer(DiagramBehavior.java:600)
at org.eclipse.graphiti.ui.editor.DiagramBehavior.initConfigurationProvider(DiagramBehavior.java:1420)
at org.eclipse.graphiti.ui.editor.DiagramBehavior.setInput(DiagramBehavior.java:385)
at org.eclipse.graphiti.ui.editor.DiagramEditor.setInput(DiagramEditor.java:307)
FUDForum. Page generated in 0.03963 seconds
