Re: Trace and Refine dependencies missed from SysML Requirements Diagram [message #1722218 is a reply to message #1722131] |
Wed, 03 February 2016 13:19 |
Hi Roberto,
the Standard profile is probably not applied on your model. To apply it:
- open the Property View
- select the root model in the Model Explorer
- in the Profile tab of the property view, select the 'Apply registered profile' button (the one with the blue and yellow colors)
- select the 'Standard' profile to be applied, press ok
- in the next dialog, select the checkbox to indicate that you want to apply the profile 'standard', press OK
You should now have access to trace and refine stereotypes
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03455 seconds
