| [CDO] Does the CDO Server product allow for gzip compression? [message #1722092] |
Tue, 02 February 2016 12:16  |
Hello all,
I've started developing a CDO compatibility plugin for the Epsilon languages [1, 2] and it is working nicely, but I would like to try enabling GZIP compression and see if it helps as well. I see that there is a GZIPStreamWrapper and a GZIPStreamWrapperInjector classes that I could use, and this thread mentions the setStreamWrapper/addStreamWrapper methods:
https://www.eclipse.org/forums/index.php/m/991500/?srch=compression+cdo#msg_991500
However, I assume I'd need to use them both in the server and the client. So far, I'm using the standard CDO Server product (as configured by Oomph), and I don't see any way to configure it to enable gzip compression. Would I need to roll my own product/application and add the GZIPStreamWrapperInjector myself?
[1]: http://eclipse.org/epsilon
[2]: https://github.com/epsilonlabs/emc-cdo
Kind regards,
Antonio
[Updated on: Tue, 02 February 2016 12:17] by Moderator
FUDForum. Page generated in 0.04181 seconds
