Papyrus Functionalities [message #1722065] |
Tue, 02 February 2016 14:56 |
Guilherme Silveira Messages: 1 Registered: February 2016 |
Hi Folks,
I am evaluating Papyrus and I would like to know if it has these functionalities I need:
- I need to create a big statechart, that has numerous concurrent states and transitions depending on these states.(IS_IN operator)
- I need to easily animate the statechart and see it running
- I need to create a panel where the user can press buttons and knobs in order to generate events for the statechart
- I need to create sequence diagrams (or timing diagram) that specify events and theirs sequence and timing
- (Optional) - From those sequence diagrams, each event will trigger a signal for the statechart, and the statechart will respond accordingly. So, there is 2 ways of interacting with the statechart: 1) with user inputs from a painel (where the user mouse click) OR 2) from a pre defined sequence of events defined in the sequence diagrams
- (Optional) - I need to export the statechart to SCXML format
[Updated on: Tue, 02 February 2016 15:32] Report message to a moderator
Re: Papyrus Functionalities [message #1722212 is a reply to message #1722065] |
Wed, 03 February 2016 12:35 |
Questions about Rhapsody should be directed to a Rhapsody forum.
Unless these questions are about Papyrus, in which case see replies
in-line, below.
HTH,
Christian
On 2016-02-02 15:14:19 +0000, Guilherme Silveira said:
> Hi Folks,
> I am evaluating Rhapsody and I would like to know if it has these
Papyrus can do big state charts. Or, at least, it aims to.
You might be interested to see what the Moka project is doing with
animation of diagrams and behaviour execution:
https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution
Papyrus is extensible, so you can create plug-ins that do almost anything.
Papyrus does both sequence and timing diagrams for UML Interactions.
Again, Papyrus is extensible, so this should be in the realm of possibility.
This is not provided by Papyrus, but you can implement your own
model-to-text transformation, or search the Internet for an existing
Papyrus extension that does this; I know of none.
FUDForum. Page generated in 0.02926 seconds
