Home » Archived » M2M (model-to-model transformation) » [ATL] transform model to metamodel with ATL
[ATL] transform model to metamodel with ATL [message #33258] Mon, 23 April 2007 04:08 Go to next message
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi All,
I want to use ATL to programatically transform a model that conforms to
eCore into an eCore model (I want to generate a MM in fact).
for now I have my xyz.ecore file as an input MM, a xxx.xyz file that is
the input Model. I set eCore as the output (file is ecore.ecore from
EMF distribution), but ATL generate a XMI file that Eclipse can not
manage.
Please Help,
Sylvain
Sylvain
Re: [ATL] transform model to metamodel with ATL [message #33293 is a reply to message #33258] Mon, 23 April 2007 04:18 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Sylvain,
Did you try to set the location of the Ecore metametamodel by URI ? I
think it should solve your problem.
Mikael
Sylvain wrote:
> Hi All,
> the input Model. I set eCore as the output (file is ecore.ecore from EMF
> distribution), but ATL generate a XMI file that Eclipse can not manage.
> Please Help,
> Sylvain
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] transform model to metamodel with ATL [message #33363 is a reply to message #33293] Mon, 23 April 2007 06:09 Go to previous message
Hi Mikael, thanks for your reply.
The problem was that my atl script was not correct, now it work ;-)
> Hi Sylvain,
> Did you try to set the location of the Ecore metametamodel by URI ? I think
> Mikael
> Sylvain wrote:
>> Hi All,
>> for now I have my xyz.ecore file as an input MM, a xxx.xyz file that is the
>> Please Help,
>> Sylvain
Sylvain
Previous Topic:[ATL Plugin] Autocompletion doesn't work
Next Topic:New ATL use case: A Metamodel Independent Approach to Difference Representation
Current Time: Sun Nov 09 01:48:07 EST 2025
Powered by FUDForum. Page generated in 0.04790 seconds
