Home » Modeling » QVT-OML » QVTo standalone: EMF package registries w/o maven/testng?
| Re: QVTo standalone: EMF package registries w/o maven/testng? [message #1721617 is a reply to message #1721609] |
Thu, 28 January 2016 11:06   |
Clever class loaders .... nightmare.
It is probably worth instrumenting EMF to log the thread, class, uri,
object hash code of every ResourceSet, Resource, EPackage that is
created. Any duplicates offers excellent opportunities for metamodel
schizophrenia.
The org.eclipse.xtext.junit4.GlobalRegistries can be used to create a
Memento so that at the end of a test session you can compare the final
state of the global registries with the initial warmed up state and so
see who is registering what.
Ed Willink
On 28/01/2016 15:32, Stefan Sobernig wrote:
> Hi Ed,
> Thx for the swift reply!
>> NEVER EVER reset the global registries.
> :) I should clarify. The app per se does not do any harm to the global
> registries.
> My suspicion is that the test harness (maven/testng) does, but bare of
> deep testng knowledge, this remains a suspicion.
>> They only initialize once
>>> through Java class loading which only occurs once.
> My suspicion is nourished by the fact, that the maven/testng
> integration (surefire) plays different tricks on class loading. See
> http://maven.apache.org/surefire/maven-surefire-plugin/examples/class-loading.html
> The QVT standalone bundle/app reuses and preserves the Eclipse's
> jar-in-jar. I played around with the various surefire parameters
> (forkCount, ...) but there was no change in misbehavior.
>> org.eclipse.xtext.junit4.GlobalRegistries has some helpful facilities
>> for rewinding the registries.
> Likely I need to watch out for such additions of other EMF aware test
> harnesses, to learn more. Mmmmh.
> Stefan
| Re: QVTo standalone: EMF package registries w/o maven/testng? [message #1722816 is a reply to message #1722768] |
Tue, 09 February 2016 06:36   |
This sounds very unlikely. IIRC the QVTo distribution structure is
rather boring; similar to many other Java projects. It should not
therefore cause problems that do not occur with other Eclipse projects
as well.
Ed Willink
On 08/02/2016 23:35, Stefan Sobernig wrote:
>> ? classpath order
> The MissingResourceException being a mere symptom, certainly, it turned
> out that maven classloader hierarchy [*] does not respect the
> jars-in-jar structure of the qvto-bundle jar (it is a jar including all
> plug-in jars and the org.eclipse.jdt.internal.jarinjarloader.*
> infrastructure).
> In a context outside maven (i.e.,
> org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader as main class) all
> works as expected, but maven's classloaders do not unfold the
> jars-in-jar into the classpath and prep them for resource resolution.
> For example, simply trying to run a basic QVTo standalone CLI app from
> within maven using
> mvn clean compile exec:java -Dexec.mainClass="at.ac.wu.nm.qvto.BasicTest"
> yields the same MissingResourceException.
> I need to find a way to customize the maven classloader hierarchy [*],
> and marry it with necessary essence of
> org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader. Alas, I am pretty
> clueless about maven internals. I need to reach out to the maven user
> list first.
> Stefan
> [*] http://maven.apache.org/guides/mini/guide-maven-classloading.html
| Re: QVTo standalone: EMF package registries w/o maven/testng? [message #1722841 is a reply to message #1722816] |
Tue, 09 February 2016 09:39   |
Hi Ed,
> rather boring;
This is not about QVTo distribution structure, it is the way the plugin
jars relevant for QVTo are wrapped into a single superjar:
I use Eclipse Tycho [1] to obtain and to repackage a number of Eclipse
plug-in jars into a Maven artifact [2]. This artifact
is effectively a "jars-in-jar":
superjar.jar
`- plugin1.jar
`- plugin2.jar
`- *.jar
`- org.eclipse.jdt.internal.jarinjarloader.*
When deployed, I set
org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader as the superjar's
main class. Then everything is fine. However, when used from within
maven (mvn compile, mvn java:exec, mvn test) the maven-internal
classpath is unaware of the jars in the superjar.
For example, (and therefore the MissingResourceException), maven
attempts to look up plugin.properties (actually at the root of
org.eclipse.emf.common*.jar) in superjar.jar, rather than
superjar.jar!org.eclipse.emf.common*.jar ...
Stefan
Current Time: Fri Nov 07 05:37:20 EST 2025
Powered by FUDForum. Page generated in 0.06285 seconds
