Unsetting stereotype optional properties [message #1720735] |
Wed, 20 January 2016 15:03 |
German Vega Messages: 104 Registered: December 2015 Location: Grenoble, France |
Hello
I have defined stereotype in a profile with one optional integer attribute (I defined the property using the UML standard primitive integer type, and multiplicity 0..1).
Afterwards, I can apply my profile to the model, and the stereotype to an element. In the property view, in the profile panel, I can edit the property of the stereotype.
However, once I have set a value, there is no way to unset the property, I must enter an integer in the form.
Is there any way in the property view GUI to unset the property ?
The ecore editor has a button "restore default value" in the properties view header, that seems to allow this, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=222754
Another doubt, not sure if it is a Payrus or an UML2 issue :
I have checked the generated ecore, after defining the profile, and the property was converted to an EAttribute of type Integer (an EDatatype defined in the UML model library http://www.eclipse.org/uml2/5.0.0/Types#//Integer) with lower bound 0 and upper bound 1.
Why is it not converted to an unsettable attribute, to be able to distinguish the case of unset versus set to to default value ( 0 in the case of integers) ?
FUDForum. Page generated in 0.03846 seconds
