Home » Modeling » Graphiti » Problem due to commit 4364ec2 (EmfService.isisObjectAlive)
Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1720316] Sat, 16 January 2016 16:11 Go to next message
I recently merged latest Graphiti master tree (2015-12-22) with my own sources, and experienced a problem in my graphical editor.
After a good deal of researching, I found that the culprit was in commit 4364ec2 (2015-10-15), specifically in the modification of EmfService.isisObjectAlive method, that was proposed here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=423018#c11
"If it has no side effect elsewhere"... Well, for me, it had.
I had a method that dynamically adds/removes a child GA, from a parent. This occurs in the context of some XXXCustomFeature.execute() call, and it's followed by a layoutPictogramElement() and an editor refresh
The problem is that now the "remove" does not work. It basically does this:
	Ellipse circle = null;
	for (GraphicsAlgorithm ga : parentGa.getGraphicsAlgorithmChildren()) {
			if (ga instanceof Ellipse) {
				circle = (Ellipse) ga;
				break;
	if (circle != null)
			parentGa.getGraphicsAlgorithmChildren().remove(circle);
But the removed GA is still shown. The problem is fixed if I revert to the old version, and consider an EObject "not alive" if its eResource is null.
public boolean isObjectAlive(EObject obj) {
		return obj != null && obj.eResource() != null;
I'm not sure of the internals, and what is exactly the concept of "Alive Object". I see that when I add the GA the method is not called, and when I delete it it's called twice (4 times if I return "alive"), I copy below the stacktraces.
Hernan
Thread [main] (Suspended (breakpoint at line 38 in EmfService))
	owns: GFWorkspaceCommandStackImpl  (id=113)
	EmfService.isObjectAlive(EObject) line: 38
	AnchorContainerDelegate(PictogramElementDelegate).isRefreshPossible(PictogramElement) line: 1203
	AnchorContainerDelegate(PictogramElementDelegate).refreshFigureForEditPart() line: 356
	ShapeEditPart.refreshVisuals() line: 704
	ShapeEditPart(AbstractEditPart).refresh() line: 725
	ShapeEditPart(AbstractGraphicalEditPart).refresh() line: 644
	ShapeEditPart.refresh() line: 596
	AnchorContainerDelegate(PictogramElementDelegate).refreshEditPartsForModelChildrenAndSourceConnections(EditPart) line: 319
	ContainerShapeEditPart(ShapeEditPart).refreshChildren() line: 685
	ContainerShapeEditPart(AbstractEditPart).refresh() line: 726
	ContainerShapeEditPart(AbstractGraphicalEditPart).refresh() line: 644
	ContainerShapeEditPart(ShapeEditPart).refresh() line: 596
	DiagramEditPart(ShapeEditPart).refreshChildren() line: 685
	DiagramEditPart(AbstractEditPart).refresh() line: 726
	DiagramEditPart(AbstractGraphicalEditPart).refresh() line: 644
	DiagramEditPart(ShapeEditPart).refresh() line: 596
	DiagramEditPart.refresh() line: 189
	owns: EMFOperationTransaction  (id=631)
	DiagramChangeListener.resourceSetChanged(ResourceSetChangeEvent) line: 116
	TransactionalEditingDomainImpl$1.run() line: 781
	TransactionalEditingDomainImpl.runExclusive(Runnable) line: 328
	TransactionalEditingDomainImpl.postcommit(InternalTransaction) line: 771
	TransactionalEditingDomainImpl.deactivate(InternalTransaction) line: 543
	EMFOperationTransaction(TransactionImpl).close() line: 712
	EMFOperationTransaction(TransactionImpl).commit() line: 474
	EMFCommandOperation(AbstractEMFOperation).execute(IProgressMonitor, IAdaptable) line: 155
	DefaultOperationHistory.execute(IUndoableOperation, IProgressMonitor, IAdaptable) line: 516
	GFWorkspaceCommandStackImpl(WorkspaceCommandStackImpl).doExecute(Command, Map<?,?>) line: 208
	GFWorkspaceCommandStackImpl(AbstractTransactionalCommandStack).execute(Command, Map<?,?>) line: 165
	GFWorkspaceCommandStackImpl.execute(Command, Map<?,?>) line: 96
	GFCommandStack.execute(Command) line: 138
	CustomAction.executeOnCommandStack(ICommand) line: 65
	CustomAction.run() line: 60
	CustomAction(Action).runWithEvent(Event) line: 473
	ActionContributionItem.handleWidgetSelection(Event, boolean) line: 595
Re: Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1720433 is a reply to message #1720316] Mon, 18 January 2016 10:52 Go to previous messageGo to next message
Hernan,
thanks for bringing this up. Could you please file a new Bugzilla to track this?
Michael
Re: Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1720439 is a reply to message #1720433] Mon, 18 January 2016 11:12 Go to previous messageGo to next message
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=486051
For the record: I experience the problem not only with the above GA removal, but with other removals.
Even worse, what happens is, not only that the removed GA are still displayed, but my business objects EMF container relationships gets corrupted.
Re: Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1724625 is a reply to message #1720439] Wed, 24 February 2016 16:46 Go to previous messageGo to next message
I'm having the same issue. For me it's a ChopBoxAnchor that is causing an NPE in DiagramChangeListener.resourceSetChanged(ResourceSetChangeEvent event). The anchor is removed from its parent (a ContainerShape) and its eContainer is null, therefore the eResource is null. This causes an NPE in DiagramChangeListener.calculateActiveContainerPe(EObject affectedElement) because its parent is null.
Re: Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1724756 is a reply to message #1724625] Thu, 25 February 2016 13:03 Go to previous messageGo to next message
Not sure if this will help anyone else, but I was able to cobble together a kludgy workaround for my use case (deleting a ChopboxAnchor) by overriding DiagramChangeListener in my DiagramBehavior implementation:
DiagramChangeListener diagramChangeListener;
protected void registerDiagramResourceSetListener() {
diagramChangeListener = new DiagramChangeListener(this) {
public NotificationFilter getFilter() {
return new NotificationFilter.Custom() {
public boolean matches(Notification notification) {
Object notifier = notification.getNotifier();
if (notifier instanceof ChopboxAnchor) {
ChopboxAnchor anchor = (ChopboxAnchor) notifier;
if (anchor.getParent()==null)
return false;
return !notification.isTouch();
TransactionalEditingDomain eDomain = getEditingDomain();
eDomain.addResourceSetListener(diagramChangeListener);
protected void unregisterDiagramResourceSetListener() {
if (diagramChangeListener != null) {
diagramChangeListener.stopListening();
TransactionalEditingDomain editingDomain = getEditingDomain();
if (editingDomain != null) {
editingDomain.removeResourceSetListener(diagramChangeListener);
Re: Problem due to commit 4364ec2 (EmfService.isisObjectAlive) [message #1724849 is a reply to message #1724756] Fri, 26 February 2016 09:24 Go to previous message
Robert,
thanks for this workaround, I just brought the fix on the way. I reverted back to the original behavior of EMFService.isAlive. That change will become effective with Neon M6. See the linked bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=486051.
Michael
Previous Topic:Resource problem in EMF Generated and Graphiti Editor
Next Topic:removing shape with attached connection issue
Current Time: Mon Oct 27 23:46:51 EDT 2025
Powered by FUDForum. Page generated in 0.07055 seconds
