[SOLVED] Xtext editor crashes when deployed as part of product [message #1720184] |
Fri, 15 January 2016 00:00 |
Jasper D. Messages: 4 Registered: January 2016 |
Junior Member |
Hi, I'm trying to make an Xtext 2.9 generated DSL editor work for an Eclipse 3 RCP application. The editor is working so far when running the *.ui project directly from Eclipse (Run as Eclipse Application).
However, when integrating the editor into an RCP app and running the product ("Launch an Eclipse application" from the product file) things get ugly.
As soon as a file with a associated file extension is opened, Eclipse shows a bunch of exceptions instead of the file.
log4j:WARN No appenders could be found for logger (org.eclipse.xtext.ui.internal.Activator).
log4j:WARN Please initialize the log4j system properly.
!ENTRY org.eclipse.ui 4 4 2016-01-15 00:27:07.468
!MESSAGE Unable to create part
!ENTRY org.eclipse.ui 4 0 2016-01-15 00:27:07.470
!MESSAGE Failed to create injector for com.example.model.Taxonomy ExtensionFactory: com.example.model.ui.TaxonomyExecutableExtensionFactory
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to create injector for com.example.model.Taxonomy ExtensionFactory: com.example.model.ui.TaxonomyExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:59)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:293)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:288)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:328)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:279)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:317)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:99)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:494)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:458)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1163)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3234)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3149)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3131)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3126)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3090)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3071)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1159)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:97)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:70)
at org.eclipse.ui.internal.handlers.ActionDelegateHandlerProxy.execute(ActionDelegateHandlerProxy.java:299)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at com.example.app.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: java.lang.RuntimeException: Failed to create injector for com.example.model.Taxonomy
at com.example.model.taxonomy.ui.internal.TaxonomyActivator.createInjector(TaxonomyActivator.java:71)
at com.example.model.taxonomy.ui.internal.TaxonomyActivator.getInjector(TaxonomyActivator.java:55)
at com.example.model.ui.TaxonomyExecutableExtensionFactory.getInjector(TaxonomyExecutableExtensionFactory.java:24)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
... 110 more
Caused by: com.google.inject.CreationException: Guice creation errors:
1) Error injecting method, java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.containers.JavaProjectsState
at org.eclipse.xtext.ui.shared.Access$InternalProviderForContribution.inject(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:75)
1 error
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:175)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at com.example.model.taxonomy.ui.internal.TaxonomyActivator.createInjector(TaxonomyActivator.java:67)
... 113 more
Caused by: java.lang.IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.containers.JavaProjectsState
at org.eclipse.xtext.ui.shared.internal.SharedStateContributionRegistryImpl.getLazySingleContributedInstance(SharedStateContributionRegistryImpl.java:97)
at org.eclipse.xtext.ui.shared.Access$InternalProviderForContribution.inject(Access.java:62)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.MembersInjectorImpl$1.call(MembersInjectorImpl.java:75)
at com.google.inject.internal.MembersInjectorImpl$1.call(MembersInjectorImpl.java:73)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.MembersInjectorImpl.injectAndNotify(MembersInjectorImpl.java:73)
at com.google.inject.internal.Initializer$InjectableReference.get(Initializer.java:147)
at com.google.inject.internal.Initializer.injectAll(Initializer.java:92)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:173)
... 118 more
!SUBENTRY 1 com.example.model.taxonomy.ui 4 0 2016-01-15 00:27:07.474
!STACK 0
1 error
... 113 more
... 118 more
I have no idea what causes this issue or how to fix it. Any ideas?
Best regards
[Updated on: Wed, 10 February 2016 17:07] Report message to a moderator
Re: Xtext editor crashes when deployed as part of product [message #1720275 is a reply to message #1720184] |
Fri, 15 January 2016 17:46 |
Junior Member |
Ok, I kinda found the cause.
Here is what I did:
- Create a new plug-in-based run configuration
- Auto add required plug-ins
- Add all plug-ins that are in the run configuration to the product via feature (it's a feature based product)
Now the exception is gone. The downside is, that some of these additional plug-ins make (unwanted) contributions to the UI of the RCP app.
org.eclipse.jdt.ui is required, not having this will result in the exception mentioned in my first post (IllegalStateException: Missing contribution for type: org.eclipse.xtext.ui.containers.JavaProjectsState).
Having it will add Java templates to the new project/file wizard as well as "Java Search" to the search dialog (Ctrl+H).
Some other plug-ins, such as org.eclipse.jdt.debug.ui which also makes unwanted UI contributions can be removed without any notable effects, while removing other plug-ins cause different exceptions (e.g. removing org.eclipse.search will cause a ClassNotFoundException).
There might be more things added to the UI, but since I use a very minimal RCP app here for testing, these remain to be discovered.
Now I'm wondering why there are dependencies on some UI components and if there is a way to get rid of these. Given the popularity of Xtext, I assume that there are quite a lot of people running Xtext based plug-ins inside standalone RCP apps, so I imagine that there is a solution/I'm doing something wrong here.
Best regards
Jasper
[Updated on: Fri, 15 January 2016 17:56] Report message to a moderator
FUDForum. Page generated in 0.03291 seconds
