Home » Modeling » TMF (Xtext) » Problem using XtextServlet in SpringBoot Application
Problem using XtextServlet in SpringBoot Application [message #1719826] Tue, 12 January 2016 06:28 Go to next message
i am trying to integrate the XtextServlet in my SpringBoot application for the web integration of my DSL.
During my request to the server i get an error from the XtextServlet:
java.lang.IllegalStateException: STREAMED
at org.eclipse.jetty.server.Request.getReader(Request.java:979) ~[jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at javax.servlet.ServletRequestWrapper.getReader(ServletRequestWrapper.java:266) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.xtext.web.servlet.HttpServiceContext.initializeParameters(HttpServiceContext.java:91) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.HttpServiceContext.<init>(HttpServiceContext.java:43) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.XtextServlet.getService(XtextServlet.java:216) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.XtextServlet.doPut(XtextServlet.java:136) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.xtext.web.servlet.XtextServlet.service(XtextServlet.java:60) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.websocket.server.WebSocketUpgradeFilter.doFilter(WebSocketUpgradeFilter.java:224) ~[websocket-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:84) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:77) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585) [jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577) [jetty-security-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515) [jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.Server.handle(Server.java:499) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544) [jetty-io-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635) [jetty-util-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555) [jetty-util-9.2.14.v20151106.jar:9.2.14.v20151106]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_60]
There is an error in java.io.BufferedReader getReader() - if getInputStream() method has been called on this request.
getInputStream() is called before from the DispatcherServlet from SpringBoot.
Do you have an idea how to avoid this error or a hint for a correct Spring Boot implementation?
Thanks in advance!
(xtext version 2.9.0)
[Updated on: Tue, 12 January 2016 20:13] by Moderator
Re: Problem using XtextServlet in SpringBoot Application [message #1720050 is a reply to message #1719826] Thu, 14 January 2016 02:16 Go to previous messageGo to next message
I fear we haven't tested it within SpringBoot so far.
Could you please file a ticket and if possible attach a project, so we can reproduce and debug?
Sven
Re: Problem using XtextServlet in SpringBoot Application [message #1746933 is a reply to message #1720050] Mon, 07 November 2016 14:08 Go to previous messageGo to next message
I've been trying to get the same thing to work today. I got the same error as described. It looks like the servlet specification does not permit calling request.getReader() more than once.
It turns out that spring auto configures filters into the web context. One of the filters OrderedHttpPutFormContentFilter makes a call request.getReader() method causing the invalid state when the Xtext Servlet also subsequently makes the same call.
To get around this I've disabled the filters: OrderedHttpPutFormContentFilter and HiddenHttpMethodFilter.
Here is the code I used.
package org.xtext.example.mydsl.web;
import java.util.ArrayList;
import org.eclipse.jetty.annotations.AnnotationConfiguration;
import org.eclipse.jetty.webapp.AbstractConfiguration;
import org.springframework.beans.BeansException;
import org.springframework.beans.factory.config.BeanFactoryPostProcessor;
import org.springframework.beans.factory.config.ConfigurableListableBeanFactory;
import org.springframework.boot.context.embedded.ConfigurableEmbeddedServletContainer;
import org.springframework.boot.context.embedded.EmbeddedServletContainerCustomizer;
import org.springframework.boot.context.embedded.jetty.JettyEmbeddedServletContainerFactory;
import org.springframework.boot.web.filter.OrderedHttpPutFormContentFilter;
import org.springframework.boot.web.servlet.FilterRegistrationBean;
import org.springframework.boot.web.servlet.ServletRegistrationBean;
import org.springframework.context.annotation.Bean;
import org.springframework.stereotype.Component;
import org.springframework.web.filter.HiddenHttpMethodFilter;
@Component
public class SpringBootJetty implements BeanFactoryPostProcessor {
@Bean
public JettyEmbeddedServletContainerFactory jettyEmbeddedServletContainerFactory() {
JettyEmbeddedServletContainerFactory jettyContainer = new JettyEmbeddedServletContainerFactory();
jettyContainer.setPort(8080);
return jettyContainer;
@Bean
public FilterRegistrationBean registration1(OrderedHttpPutFormContentFilter filter) {
FilterRegistrationBean registration = new FilterRegistrationBean(filter);
registration.setEnabled(false);
return registration;
@Bean
public FilterRegistrationBean registration2(HiddenHttpMethodFilter filter) {
public void postProcessBeanFactory(ConfigurableListableBeanFactory bf)
throws BeansException {
// You can iterate through all the filters and disable.....
// DefaultListableBeanFactory beanFactory = (DefaultListableBeanFactory) bf;
// Arrays.stream(beanFactory.getBeanNamesForType(javax.servlet.Filter.class))
// .forEach(name -> {
// BeanDefinition definition = BeanDefinitionBuilder
// .genericBeanDefinition(FilterRegistrationBean.class)
// .setScope(BeanDefinition.SCOPE_SINGLETON)
// .addConstructorArgReference(name)
// .addConstructorArgValue(new ServletRegistrationBean[]{})
// .addPropertyValue("enabled", false)
// .getBeanDefinition();
// beanFactory.registerBeanDefinition(name + "FilterRegistrationBean",
// definition);
@Bean
public ServletRegistrationBean xtextServletRegistrationBean() {
ServletRegistrationBean bean = new ServletRegistrationBean(new MyDslServlet(), "/xtext-service/*");
bean.setName("XtextService");
bean.setOrder(ServletRegistrationBean.HIGHEST_PRECEDENCE);
bean.setOrder(100);
return bean;
Hope this gets you further on.
Cheers
Anthony
[Updated on: Mon, 07 November 2016 14:39] by Moderator
Re: Problem using XtextServlet in SpringBoot Application [message #1752918 is a reply to message #1746933] Mon, 30 January 2017 11:31 Go to previous messageGo to next message
Hello Anthony,
Thanks a lot for your answer. I ended up facing the same error, and your solution got me out of it. Looks like we are doing something very similar. I guess it would be cool if we could collaborate a bit and do some information exchange. Would you be interested?
@Cornelius: How about you?
Sandeep Joseph
SAP SE
Re: Problem using XtextServlet in SpringBoot Application [message #1780966 is a reply to message #1752918] Tue, 30 January 2018 10:05 Go to previous messageGo to next message
The problem is with xtext using application/x-www-form-urlencoded as the content type for the payload. This causes the springboot filter to read the stream and parse the data.
Even if you disable the filter, eventually you will still have a problem with app servers like Undertow parsing the payload on their HttpServerRequest implementation and putting into their own FormData representation causing the XTextServlet no longer able to read the payload and hence not behaving properly. In the scenario I just described, it will cause the fullText to be null and cause further error.
I suggest that Xtext Web to introduce their own proprietary Content-Type instead of using the standard application/x-www-form-urlencoded as content type. Thay way no generic filters or web server implementations will interfere. Of course the downside will be having to add the Xtext Content-Type to the web server as an allowed Content-Type
Re: Problem using XtextServlet in SpringBoot Application [message #1781045 is a reply to message #1780966] Wed, 31 January 2018 13:35 Go to previous messageGo to next message
Please file bug at github.com/eclipse/Xtext-web
But I fear there is currently nobody willing to work on this
So you would have to come up with a patch yourself
Re: Problem using XtextServlet in SpringBoot Application [message #1793582 is a reply to message #1781045] Fri, 10 August 2018 09:39 Go to previous message
Perhaps one could circumvent the issue by putting another filter mapped to XtextServlet path that would cache input stream in memory and allow for multiple calls of getReader.
One can check this StackOverflow question to see how that can be implemented: https://stackoverflow.com/questions/4449096/how-to-read-request-getinputstream-multiple-times
The filter should be called before Spring's filters though.
Previous Topic:Context aware grammar help
Next Topic:How to multi selection in the xtext Content Assist
Current Time: Mon Oct 27 19:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.04742 seconds
