Home » Eclipse Projects » Eclipse 4 » MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt&quo(Problem rendering SWT from 3.7 to 4.4)
MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt&quo [message #1719407] Thu, 07 January 2016 12:03 Go to next message
I'm porting an RCP application from eclipse 3.7 to 4.4. I followed a tutorial to use the compatibility Layer.
When I try to run my application in the Eclipse 4.4, I have a runderring problem caused by swt, and so nothing is shown
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.723
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/Context/context/SET].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.738
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/renderer/SET].
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.754
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/widget/SET].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.769
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.801
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/persistedState/ADD].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.894
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/basic/Window/width/SET].
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/basic/Window/height/SET].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.910
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/basic/Window/sharedElements/ADD].
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD].
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/SET].
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/SET].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:23.925
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/transientData/ADD].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.300
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.301
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/renderer/requestEnablementUpdate].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.316
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.332
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.348
!MESSAGE Event Admin service is not available, unable to publish event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/basic/Window/mainMenu/SET].
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.363
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-01-07 10:28:24.379
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2016-01-07 10:28:24.379
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:85)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1480)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1453)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:943)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:137)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:703)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1060)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1666)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2151)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4607)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1626)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5023)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:230)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:744)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at com.natixis.etrading.fxalgo.gui.Application.start(Application.java:278)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4061)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:733)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
... 53 more
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@dd69450 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {FX Smart : UAT - 2015.2.28 - HFEKI}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@2f577b30, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: %trimmedwindow.label.eclipseSDK, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: -2147483648, y: -2147483648, width: 400, height: 300)
!STACK 0
... 53 more
Have ou faced before this kind of problem, and is there a solution for that ?
Thank you in advance
Re: MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt [message #1719535 is a reply to message #1719407] Fri, 08 January 2016 12:14 Go to previous message
Looks like you're missing the org.eclipse.equinox.event bundle. Be sure to bring in the org.eclipse.rcp bundle or carefully check your dependencies.
Previous Topic:Reset Perspective closes all minimized view
Next Topic:SWT table widget and multi column sorting
Current Time: Wed Sep 17 11:41:12 EDT 2025
Powered by FUDForum. Page generated in 0.02853 seconds
