runner fails to execute correctly on windows server 2008R2 [message #1719388] |
Thu, 07 January 2016 15:30 |
All these suites and tests run successfully in the IDE
case 1: execute runner from windows server 2008R2 task scheduler:
workspace/metadata/.log
!SESSION 2016-01-07 09:43:08.620 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_80
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application org.eclipse.rcptt.runner.headless -aut C:\iit\iIT-7.0.5 -autWsPrefix C:\inetpub\wwwroot\reports\runner/aut-workspace -autConsolePrefix C:\inetpub\wwwroot\reports\runner/aut-output -htmlReport C:\inetpub\wwwroot\reports\runner/report.html -junitReport C:\inetpub\wwwroot\reports\runner/report.xml -import C:\development\suites\q7\projects\exports -suites IIT_testing;channelbuilder;newchannelwizard;channeleditor;applicationbuilder;newapplicationwizard;applicationeditor
Command-line arguments: -application org.eclipse.rcptt.runner.headless -data C:\inetpub\wwwroot\reports\runner/runner-workspace/ -aut C:\iit\iIT-7.0.5 -autWsPrefix C:\inetpub\wwwroot\reports\runner/aut-workspace -autConsolePrefix C:\inetpub\wwwroot\reports\runner/aut-output -htmlReport C:\inetpub\wwwroot\reports\runner/report.html -junitReport C:\inetpub\wwwroot\reports\runner/report.xml -import C:\development\suites\q7\projects\exports -suites IIT_testing;channelbuilder;newchannelwizard;channeleditor;applicationbuilder;newapplicationwizard;applicationeditor
!ENTRY org.eclipse.jdt.launching.macosx 4 0 2016-01-07 09:43:10.430
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.macosx
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.os=macosx)"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.jdt.launching.ui.macosx 4 0 2016-01-07 09:43:14.065
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.ui.macosx
!ENTRY org.eclipse.emf.workspace.ui 4 0 2016-01-07 09:43:14.112
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.workspace.ui [309]
Unresolved requirement: Require-Bundle: org.eclipse.emf.edit.ui; bundle-version="[2.3.0,3.0.0)"; visibility:="reexport"
!ENTRY org.eclipse.rcptt.launching.ext 2 0 2016-01-07 09:43:21.366
!MESSAGE Detected potential problems in target platform No Name
Installation C:\iit\iIT-7.0.5 Default Configuration
Directory C:\iit\iIT-7.0.5\plugins
Env: null/null/null/null
JRE: null
Args: null/null
Implicit: null
Handle: 1452177795297.target
!SUBENTRY 1 org.eclipse.rcptt.launching.ext 2 0 2016-01-07 09:43:21.366
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/com.google.inject_3.0.0.v201312141243.jar and file:/C:/iit/iIT-7.0.5/plugins/com.google.inject_2.0.0.v201105231817.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.apache.lucene_2.9.1.v201101211721.jar and file:/C:/iit/iIT-7.0.5/plugins/org.apache.lucene_1.9.1.v201101211617.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.junit_4.8.2.v4_8_2_v20110321-1705/ and file:/C:/iit/iIT-7.0.5/plugins/org.junit_3.8.2.v3_8_2_v20100427-1100/
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.objectweb.asm_5.0.1.v201404251740.jar and file:/C:/iit/iIT-7.0.5/plugins/org.objectweb.asm_3.3.1.v201105211655.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.junit.source_4.8.2.v4_8_2_v20110321-1705.jar and file:/C:/iit/iIT-7.0.5/plugins/org.junit.source_3.8.2.v3_8_2_v20100427-1100.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/com.google.inject_2.0.0.v201105231817.jar and file:/C:/iit/iIT-7.0.5/plugins/com.google.inject_3.0.0.v201312141243.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.apache.lucene_1.9.1.v201101211617.jar and file:/C:/iit/iIT-7.0.5/plugins/org.apache.lucene_2.9.1.v201101211721.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.junit.source_3.8.2.v3_8_2_v20100427-1100.jar and file:/C:/iit/iIT-7.0.5/plugins/org.junit.source_4.8.2.v4_8_2_v20110321-1705.jar
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.junit_3.8.2.v3_8_2_v20100427-1100/ and file:/C:/iit/iIT-7.0.5/plugins/org.junit_4.8.2.v4_8_2_v20110321-1705/
!MESSAGE Multiple versions of bundle file:/C:/iit/iIT-7.0.5/plugins/org.objectweb.asm_3.3.1.v201105211655.jar and file:/C:/iit/iIT-7.0.5/plugins/org.objectweb.asm_5.0.1.v201404251740.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:21.647
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.runtime/q7/content.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:21.959
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:22.224
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.runtime/q7/artifacts.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:28.667
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.aspectj.e3x/dependencies/content.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:28.792
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.aspectj.e3x/dependencies/artifacts.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:29.556
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.helios/dependencies/content.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:29.806
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.updates.helios/dependencies/artifacts.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:34.517
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.module.nebula.updates/runtime/content.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:34.642
!MESSAGE Server returned lastModified <= 0 for platform:/plugin/org.eclipse.rcptt.module.nebula.updates/runtime/artifacts.jar
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:35.157
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:35.437
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:35.562
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:35.812
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:36.405
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:36.529
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:36.639
!ENTRY org.eclipse.equinox.p2.repository 2 0 2016-01-07 09:43:36.763
!ENTRY org.eclipse.core.resources 2 10035 2016-01-07 09:43:51.818
!MESSAGE The workspace will exit with unsaved changes in this session.
batch cmd log:
iIT RCPT (q7) testing started...
C:\development\support\tools\scripts\cmd>RMDIR /S /Q C:\inetpub\wwwroot\reports\runner
C:\development\support\tools\scripts\cmd>md C:\inetpub\wwwroot\reports\runner
C:\development\support\tools\scripts\cmd>java -jar C:\rcptt\runner\windows\eclipse/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar -application org.eclipse.rcptt.runner.headless -data C:\inetpub\wwwroot\reports\runner/runner-workspace/ -aut C:\iit\iIT-7.0.5 -autWsPrefix C:\inetpub\wwwroot\reports\runner/aut-workspace -autConsolePrefix C:\inetpub\wwwroot\reports\runner/aut-output -htmlReport C:\inetpub\wwwroot\reports\runner/report.html -junitReport C:\inetpub\wwwroot\reports\runner/report.xml -import C:\development\suites\q7\projects\exports -suites IIT_testing;channelbuilder;newchannelwizard;channeleditor;applicationbuilder;newapplicationwizard;applicationeditor
Started at Thu Jan 07 09:43:14 EST 2016
RCPTT Runner version: 2.1.0
Initializing target platform...
Target platform is valid.
Looking for tests...
Existing projects in workspace:
<none>
Importing projects to workspace:
Refreshing projects:
C:\development\suites\q7\projects\exports\applicationeditor... OK
C:\development\suites\q7\projects\exports\application_builder... OK
C:\development\suites\q7\projects\exports\channeleditor... OK
C:\development\suites\q7\projects\exports\channel_builder... OK
C:\development\suites\q7\projects\exports\IIT_testing... OK
C:\development\suites\q7\projects\exports\newapplicationwizard... OK
C:\development\suites\q7\projects\exports\newchannelwizard... OK
IIT_testing... OK
channeleditor... OK
Searching for tests in projects:
IIT_testing...
No tests found
No tests found
No tests found
channel_builder...
No tests found
channeleditor...
No tests found
No tests found
newchannelwizard...
No tests found
No tests to run.
Finished at Thu Jan 07 09:43:50 EST 2016
iIT RCPT (q7) testing ended...
case two - manual execution of the same batch command:
C:\development\support\tools\scripts\cmd>q7_iit_tests.cmd
Started at Thu Jan 07 09:48:56 EST 2016
<none>
IIT_testing... OK
channeleditor... OK
IIT_testing...
No tests found
No tests found
No tests found
channel_builder...
No tests found
channeleditor...
No tests found
No tests found
newchannelwizard...
No tests found
No tests to run.
Finished at Thu Jan 07 09:49:33 EST 2016
case 3-same batch command manually executed modified to not specify suites:
ts\exports
Started at Thu Jan 07 09:55:45 EST 2016
<none>
IIT_testing... OK
channeleditor... OK
IIT_testing...
Complete OK
No tests found
Complete OK
channel_builder...
No tests found
channeleditor...
Complete OK
Complete OK
newchannelwizard...
-- Testcase is skipped by tag "skipExecution" -- 007_load_additional_target_server_version.test
Complete OK
Testcase Artifacts:258
AUT-0:Launching
AUT-0:Product: com.iwaysoftware.integration.tools.product
AUT-0:Application: org.eclipse.ui.ide.workbench
AUT-0:Architecture: x86_64
64bit arch is selected because AUT uses launcher library
"plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.100.v20110502" specified in config file: iit.ini
C:\inetpub\wwwroot\reports\runner/aut-workspace0: AUT arguments: -os ${target.os} -arch ${target.arch} -consoleLog
C:\inetpub\wwwroot\reports\runner/aut-workspace0: AUT VM arguments: -XX:MaxPermSize=256M -Xms512M -Xmx1024M -Djava.util.Arrays.useLegacyMergeSort=true
Fail 1 (258) processed. 1 failed. spent: 0:02, 2:50 mins remaining. testit. time: 2389ms Cause: Undeclared val 'channelProjectName'
Fail 2 (258) processed. 2 failed. spent: 0:03, 4:16 mins remaining. 001_Add_Application_Component_Flow. time: 468ms Cause: Scriptlet Create_project not found
Fail 3 (258) processed. 3 failed. spent: 0:04, 4:15 mins remaining. 002_Add_Application_Component_Channel. time: 452ms Cause: Scriptlet Create_project not found
Fail 4 (258) processed. 4 failed. spent: 0:06, 4:13 mins remaining. 003_Add_Application_Component_Transform. time: 531ms Cause: Scriptlet Create_project not found
Fail 5 (258) processed. 5 failed. spent: 0:06, 3:36 mins remaining. 004_Add_Application_Business_Service. time: 436ms Cause: Scriptlet Create_project not found
Fail 6 (258) processed. 6 failed. spent: 0:07, 3:39 mins remaining. 005_Add_Application_Lib. time: 469ms Cause: Scriptlet Create_project not found
Continued...
Fail 254 (258) processed. 253 failed. spent: 5:55, 0:04 mins remaining. 020_add_multiple_outbound_protocols_with_outlets_for_each. time: 4821ms Cause: The control "Finish" is disabled.
Fail 255 (258) processed. 254 failed. spent: 6:00, 0:02 mins remaining. 021_add_outbound_protocols_which_exceed_dialog_display_list. time: 4790ms Cause: The control "Finish" is disabled.
Fail 256 (258) processed. 255 failed. spent: 6:05, 0:01 mins remaining. 022_add_outbound_protocol_with_changed_name_and_description. time: 4836ms Cause: The control "Finish" is disabled.
Fail 257 (258) processed. 256 failed. spent: 6:10, 0:00 mins remaining. 023_change_an_outbound_protocol_listener_to_a_duplicate_name. time: 4992ms Cause: The control "Finish" is disabled.
Fail 258 (258) processed. 257 failed. spent: 6:16, 0:00 mins remaining. try. time: 5039ms Cause: The control "Finish" is disabled.
Failed Tests:
006_erase_new_channel_name_with_the_keyboard
017_Delete_Application_Lib
002_start_new_channel_and_cancel
012_process_resource_selection
061_menu_add_channel_component_encryptor
042_icon_add_components_in_transformer
015_add_inbound_protocol_with_changed_name_and_description
163_Edit_Outlet_Description_With_Properties_View
053_menu_add_channel_component_reviewer
036_icon_add_components_decryptor
091_import_transform_from_library_manager
041_menu_add_channel_component_in_transformer
162_Edit_transform_Description_With_Properties_View
151_Edit_Decryptor_Description_With_Properties_View
122_Change_In_Transformer_Name_With_Properties_View
012_Add_Application_JDCB_Binding
007_Add_Application_Rescource_File
044_icon_add_components_reviewer
027_Keyboard_Delete_Application_Component_Flow
147_Change_Emitter_Name_With_Editor_Tree_View
164_Edit_Encryptor_Description_With_Properties_View
124_Change_reviewer_Name_With_Properties_View
017_select_outbound_protocol_with_filter
065_menu_add_channel_component_emitter
try
008_Add_Application_Resource_Folder
014_Delete_Application_Component_Channel
143_Change_Encryptor_Name_With_Editor_Tree_View
139_Change_transform_Name_With_Editor_Tree_View
025_locate_route_process_error
011_Add_Application_Register_Binding
125_Change_reviewer_Name_With_Editor_Tree_View
007_delete_listener_in_editor_tree
066_icon_add_components_emitter
142_Change_Encryptor_Name_With_Properties_View
035_menu_add_channel_component_decryptor
001_create_a_new_channel
168_Move_Route_Up
006_delete_listener_with_icon
067_add_channel_register_set
021_change_the_default_route
153_Edit_Route_Description_With_Properties_View
020_Add_Folder_For_Application
Continued ...
140_Change_Outlet_Name_With_Properties_View
031_Keyboard_Delete_Application_Lib
037_menu_add_channel_component_preparser
106_export_preemitter_to_library_manager
137_Change_rule_Name_With_Editor_Tree_View
099_import_rule_from_library_manager
Process terminated. Shut down AUTs
Re: runner fails to execute correctly on windows server 2008R2 [message #1719429 is a reply to message #1719388] |
Thu, 07 January 2016 20:08 |
I have developed a workaround that is totally unacceptable going forward:
- create a project and put all the context files in that project.
- put the tests for a particular feature in that project
- code the runner without the -suites and -tests options
this is working but is can't be reasonably maintained as the number of features to test increases and if some of the proc contexts need to change.
FUDForum. Page generated in 0.04183 seconds
