| Deploy rwt standalone not work [message #1719368] | Thu, 07 January 2016 08:55  |  |
| Eclipse User  |  |  |  |  | Hello, i create a RWT standalone (as servlet) in projet java with this tuto : http://www.eclipse.org/rap/developers-guide/devguide.php?topic=rwt-standalone.html&version=3.0
 If i launch with web.xml, it works.
 Now, i want to deploy this app in embedded jetty server with spring.
 if i deploy the rwt servlet, ApplicationConfiguration is reading (title of tab is correct) but the page is blank.
 Jetty code to launch RWT Servlet :
  public static void main(String[] args) throws Exception
    new EmbeddedJetty().startJetty(getPortFromArgs(args));
 private void startJetty(int port) throws Exception
    logger.debug("Starting server at port {}", port);
    Server server = new Server(port);
    // lacement bis de rap
    WebAppContext appRap = new WebAppContext();
    appRap.setContextPath("/");
    appRap.setResourceBase(".");
    appRap.setDefaultsDescriptor("src/main/java/test/rap/WEB-INF/web.xml");
    server.setHandler(appRap);
    server.start();
    logger.info("Server started at port {}", port);
    server.join();
 AppConfiguration :
public class AppConfiguration implements ApplicationConfiguration
  public void configure(Application application)
    Map<String, String> properties = new HashMap<String, String>();
    properties.put( WebClient.PAGE_TITLE, "Hello world rap" );
    application.addEntryPoint("/rap", HelloWorld.class, properties);
public class HelloWorld extends AbstractEntryPoint
  private static final long serialVersionUID = 1L;
  public void createContents(Composite parent)
    Label label = new Label(parent, SWT.NONE);
    label.setText("Hello RAP World");
 Anyone has ideas? Or example of rwt standalone application deployed in embedded jetty server ?
 I attach my project. Launch EmbeddyJetty as application java.
 [Updated on: Thu, 07 January 2016 09:04] by Moderator |  |  |  |
FUDForum. Page generated in 0.03933 seconds
