Home » Eclipse Projects » Remote Application Platform (RAP) » TableViewer in Dialog does not show any labels(The TableViewer in a costumDialog contains values, but does not show any name in the column)
TableViewer in Dialog does not show any labels [message #1719255] Wed, 06 January 2016 10:52 Go to next message
Hi there,
i got following the problem:
I build a costum dialog extending the jface dialog class. There i want to show a table using the jface tableViewer with one column and text in it.
I did the following in my dialog class to create the tableviewer:
protected Control createDialogArea(Composite parent) {
Composite comp = (Composite) super.createDialogArea(parent);
comp.setLayout(new GridLayout(1, true));
tableViewer = new TableViewer(comp, SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
tableViewer.getControl().setLayoutData(new GridData(SWT.FILL, SWT.FILL, true,true,1,1));
final Table table = tableViewer.getTable();
table.setHeaderVisible(true);
table.setLinesVisible(true);
tableViewer.setContentProvider(new MyContentProvider());
TableViewerColumn col1 = new TableViewerColumn(tableViewer, SWT.NONE);
col1.getColumn().setText("Component Model Name");
col1.setLabelProvider(new ColumnLabelProvider() {
public String getText(Object element) {
return "test";
tableViewer.setInput(inputObject);
Now the table viewer shows elements in it and you can choose them and when you click the ok button it knows the tableViewer.getSelection() element and everything works fine. Besides the problem that the viewer does not show the string "test" or any string in its appearance.
the outcome looks like:
index.php/fa/24516/0/
index.php/fa/24517/0/
Any suggestions? Smile
Greetings, lars
  • Attachment: 2.PNG
    (Size: 5.39KB, Downloaded 352 times)
  • Attachment: 1.PNG
    (Size: 5.88KB, Downloaded 319 times)
[Updated on: Wed, 06 January 2016 10:54] by Moderator
Re: TableViewer in Dialog does not show any labels [message #1719268 is a reply to message #1719255] Wed, 06 January 2016 12:09 Go to previous messageGo to next message
try so add columns
new TableColumn(tableViewer.getTable(), SWT.LEFT).setText("test1");
tableViewer.getTable().getColumn(1).pack();
new TableColumn(tableViewer.getTable(), SWT.LEFT).setText("testN");
tableViewer.getTable().getColumn(N).pack();
[Updated on: Thu, 07 January 2016 07:28] by Moderator
Re: TableViewer in Dialog does not show any labels [message #1719717 is a reply to message #1719268] Mon, 11 January 2016 11:33 Go to previous message
Thanks man that solved my problem Smile
Best regards
lars
Previous Topic:Start a rwt standalone app with jetty and spring
Next Topic:[SOLVED] RAP E4 - Window properties and Tags
Current Time: Thu Nov 06 08:51:10 EST 2025
Powered by FUDForum. Page generated in 0.03014 seconds
