Re: Problem with the Create Node Tool [message #1719000 is a reply to message #1718880] |
Mon, 04 January 2016 11:09 |
Le 31/12/2015 17:26, Francesco Gallo a écrit :
Hello
> I have my file .ecore and I would like create a sirius editor for some elements of it. (xml file attached)
> I created a palette to add some nodes, but when I try to add a node, it is not appear in diagram.... (png file attached).
First of all, make sure that you 've defined a correct mapping so that
you semantic object can be displayed in your diagram. See "Add a Node to
the Layer" in the starter tutorial [1].
You can add a new semantic object, opening your semantic/business model
in the EMF reflexive editor.
Then, the paragraph "Define the actions performed by the Create Node
tool"[1] should provides all your need to help you create your create tool.
Refer also to the sirius documentation [2] [3] to know more about
CreateInstance and ChangeContext Operation
> Sorry, but I am Sirius newbie :(.. I looked the tutorial, but the metamodel example is very different from my...
> Please, Is There someone that help me?
> Regards
[1] https://wiki.eclipse.org/Sirius/Tutorials/StarterTutorial
[2]
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.sirius.doc%2Fdoc%2Fspecifier%2Fgeneral%2FModel_Operations.html&cp=69_2_5_0&anchor=create_instance
[3]
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.sirius.doc%2Fdoc%2Fspecifier%2Fgeneral%2FModel_Operations.html&cp=69_2_5_0&anchor=flow
Laurent
Laurent Fasani - Obeo
FUDForum. Page generated in 0.03659 seconds
