Home » Eclipse Projects » Sirius » NullPointerException during programmatically generation of diagram Images
NullPointerException during programmatically generation of diagram Images [message #1718384] Wed, 23 December 2015 03:30 Go to next message
i am trying to generate Images of programmatically generated diagrams. I have Rectangles with rounded corners and during the paint methods sub calls the image creation fails.
I think it fails because the OneLineMarginBorder objects int[] dash attribute is a null reference.
Is this a bug? Is there any workaround to avoid this?
Best regards
Mehmet Karaman
Caused by: java.lang.NullPointerException
	at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.graphics.GraphicsToGraphics2DAdaptor.setLineDash(GraphicsToGraphics2DAdaptor.java:1124)
	at org.eclipse.gmf.runtime.draw2d.ui.internal.graphics.ScaledGraphics.setLineDash(ScaledGraphics.java:802)
	at org.eclipse.sirius.diagram.ui.tools.api.figure.OneLineMarginBorder.paint(OneLineMarginBorder.java:56)
	at org.eclipse.sirius.diagram.ui.tools.internal.figure.RoundedCornerMarginBorder.paint(RoundedCornerMarginBorder.java:67)
	at org.eclipse.draw2d.Figure.paintBorder(Figure.java:1137)
	at org.eclipse.draw2d.Figure.paint(Figure.java:1121)
	at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1170)
	at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1205)
	at org.eclipse.draw2d.Figure.paint(Figure.java:1120)
	at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1200)
	at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:160)
	at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1209)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.paintFigure(DiagramGenerator.java:373)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.renderToGraphics(DiagramGenerator.java:226)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.createSWTImageDescriptorForParts(DiagramGenerator.java:721)
	at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:376)
	at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:305)
	... 127 more
Re: NullPointerException during programmatically generation of diagram Images [message #1718417 is a reply to message #1718384] Wed, 23 December 2015 08:47 Go to previous messageGo to next message
Hi Mehmet,
Thank you for your feedback,
Bug 484507 [1] has been created last week for the same NPE but in
another scenario (menu > copy, which on Windows place the result of a
CoptyToImage in the system clipboard).
A patch has already been provided, but the issue has not yet been added
to any roadmap. The patch targets master and the issue has been marked
as potential target for a backport on maintenance branches.
Do you have compartments on your diagrams ?
Maxime
Le 23/12/2015 09:30, Emin M. a écrit :
> Hello,
> Best regards
> Mehmet Karaman
> at
> ... 127 more
Maxime - Obeo
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=484507
Re: NullPointerException during programmatically generation of diagram Images [message #1718424 is a reply to message #1718417] Wed, 23 December 2015 09:40 Go to previous messageGo to next message
Thank you for the reply.
Yes i have compartments. Is this problem related to compartments or rounded corner diagram elements?
[Updated on: Wed, 23 December 2015 09:45] by Moderator
Re: NullPointerException during programmatically generation of diagram Images [message #1718430 is a reply to message #1718424] Wed, 23 December 2015 10:17 Go to previous message
This issue is related to compartments and their shared border, as soon
as there is more than one compartment in the same container.
Maxime - Obeo
Previous Topic:Tree element label goes blank when selected
Next Topic:Label Expression with String
Current Time: Sat Nov 08 14:03:21 EST 2025
Powered by FUDForum. Page generated in 0.02981 seconds
