Home » Language IDEs » PHP Development Tools (PDT) » RUN as PHP CLI(Run PHP scripts without web server?)
RUN as PHP CLI [message #1717337] Fri, 11 December 2015 16:10 Go to next message
Eclipse and PDT installed
PHP installed
PHP executable path set up in eclipse (c:\php)
Just want to run simple hello world scirpt without setting up web server.
When I Run As - PHP CLI application nothing happens.
I would expect it to do like java and find the php.exe and spit the output into the console. I can run the script from the command prompt c:\php\php.exe helloworld.php fine. Can't I do this in eclipse?
Why is this so hard?
Re: RUN as PHP CLI [message #1717513 is a reply to message #1717337] Mon, 14 December 2015 08:57 Go to previous messageGo to next message
Please show you code.
Re: RUN as PHP CLI [message #1717551 is a reply to message #1717513] Mon, 14 December 2015 11:35 Go to previous messageGo to next message
If you go into Windows->Preferences->PHP->PHP Executables, do you have a PHP Executable set up? If not, add one there and then it should work. Good luck.
Re: RUN as PHP CLI [message #1720820 is a reply to message #1717551] Thu, 21 January 2016 04:25 Go to previous messageGo to next message
look for lines that starts with LoadModule php... There propably is configuration files/directories named mods or something like that, start from there.
You could also check output from php -r 'phpinfo();' | grep php and compare lines to phpinfo(); from web server.
To run php interactively
so you can paste/write code to console run it with:
php -a
To make it parse file and output to console:
php -f file.php
Parse file and output to another file:
php -f file.php > reults.html
Re: RUN as PHP CLI [message #1723833 is a reply to message #1720820] Thu, 18 February 2016 05:48 Go to previous messageGo to next message
I am agree with "Mark DexterFriend" but its better if you show your code here
Re: RUN as PHP CLI [message #1723949 is a reply to message #1723833] Fri, 19 February 2016 03:28 Go to previous message
It's worth adding that PHP from version 5.4 onwards is able to run a web server on its own. You can do it by running this code in a folder which you want to serve the pages from:
$ php -S localhost:8000
Previous Topic:Postgres and PDT
Next Topic:Eclipse freezes when browsing PHP Explorer
Current Time: Wed Jun 18 18:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.26492 seconds
