Home » Newcomers » Newcomers » Eclipse 4.5.1 under Ubuntu 15.10 and "install New Software"(user rights issue to install new software)
icon5.gif  Eclipse 4.5.1 under Ubuntu 15.10 and "install New Software" [message #1717232] Thu, 10 December 2015 16:44 Go to next message
previously i was running Eclipse under Windows without any issue.
Now i migrated to Ubuntu 15.10 and i installed Eclipse 4.5.1 (so Mars version) without any issue.
I wanted to install RSE (remote system explorer) so part of TM (target management) using my common user. However the button "Next" to install the software was disable.
If i launch eclipse as root, and do the same thing, i can click on Next button to install the software.
From my point of view that's a little weird as a common user could need at any time to install/upgrade eclipse, adding new eclipse's part/software.
SO i would like to know what should i do to make my standard user be able to install new software without being forced to do it under root ?
is there a file permission to change ? all my eclipse files are owned by my common user "alain"
thx a lot.
Re: Eclipse 4.5.1 under Ubuntu 15.10 and "install New Software" [message #1717314 is a reply to message #1717232] Fri, 11 December 2015 11:05 Go to previous messageGo to next message
How and where did you install Eclipse?
Re: Eclipse 4.5.1 under Ubuntu 15.10 and "install New Software" [message #1717316 is a reply to message #1717314] Fri, 11 December 2015 11:19 Go to previous message
as i'm under linux, i just untar the file in my /home/alain/appz/eclipse directory
I created a ubuntu launcher to run it from my desktop or from DE menu from development menu.
It runs under my common user account so "alain"
[Updated on: Fri, 11 December 2015 12:02] by Moderator
Previous Topic:Eclipse is not suggesting click() and sendKey() function in selenium
Next Topic:Just a starting point
Current Time: Wed Sep 10 17:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.05935 seconds
