Home » Modeling » TMF (Xtext) » Default Scope Shadowing
Default Scope Shadowing [message #1716439] Thu, 03 December 2015 15:26 Go to next message
I'm working through Lorenzo Bettini's book, and have gotten to the section on scoping. I'm reading the ebook, and at location 4124, he briefly discusses shadowing and proposes this test to verify that the default ScopeProvider will properly provide shadowing.
	@Test def void testVariableShadowsParamLinking() {
		class A {
			A m(A a) {
				A a = null;
				return a;
		'''.parse.classes.head.methods.head => [
			assertNoErrors
			// the local variable should shadow the param
			body.statements.head.assertSame(
				(returnStatement.expression as SJSymbolRef).symbol)
However, this test fails for me with the default provider. Am I missing something, or is this just an incorrect statement from the book, or something that worked "out of the box" in prior versions of Xtext? The test passes with the custom ScopeProvider implementation presented later in the chapter.
Thanks!
Re: Default Scope Shadowing [message #1716448 is a reply to message #1716439] Thu, 03 December 2015 18:57 Go to previous messageGo to next message
Specifically, implementation of this code in SmallJavaScopeProvider makes things behavior as expected:
	def scope_SJSymbolRef_symbol(SJExpression context, EReference r) {
		context.eContainer.symbolsDefinedBefore(context)
	def dispatch IScope symbolsDefinedBefore(EObject cont, EObject o) {
		cont.eContainer.symbolsDefinedBefore(o.eContainer)
	def dispatch IScope symbolsDefinedBefore(SJMethod m, EObject o) {
		Scopes::scopeFor(m.params) // ends recursion
	def dispatch IScope symbolsDefinedBefore(SJBlock b, EObject o) {
		Scopes::scopeFor(b.statements.variablesDeclaredBefore(o),
			// outer scope
			b.eContainer.symbolsDefinedBefore(o.eContainer))
	def private variablesDeclaredBefore(List<SJStatement> list, EObject o) {
		list.subList(0,list.indexOf(o)).filter(SJVariableDeclaration)
Re: Default Scope Shadowing [message #1716483 is a reply to message #1716439] Fri, 04 December 2015 05:24 Go to previous messageGo to next message
> class A {
> A m(A a) {
> A a = null;
> return a;
> assertNoErrors
> in the chapter.
how does this test fail with the default scope provider? I mean, does
assertNoErrors fail or the other assert?
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Default Scope Shadowing [message #1717223 is a reply to message #1716483] Thu, 10 December 2015 15:28 Go to previous messageGo to next message
Sorry, I didn't see that you had responded here. It is the second assert which reports the error:
body.statements.head.assertSame((returnStatement.expression as SJSymbolRef).symbol)
The error is:
java.lang.AssertionError: expected same:<org.example.smalljava.smallJava.impl.SJVariableDeclarationImpl@235a0c16 (name: a)> was not:<org.example.smalljava.smallJava.impl.SJParameterImpl@4b9df8a (name: a)>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotSame(Assert.java:828)
at org.junit.Assert.assertSame(Assert.java:771)
at org.junit.Assert.assertSame(Assert.java:782)
at org.example.smalljava.tests.SmallJavaScopeProviderTest.lambda$2(SmallJavaScopeProviderTest.java:159)
at org.example.smalljava.tests.SmallJavaScopeProviderTest$$Lambda$5/1426725223.apply(Unknown Source)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at org.example.smalljava.tests.SmallJavaScopeProviderTest.testVariableShadowsParamLinking(SmallJavaScopeProviderTest.java:161)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.eclipse.xtext.junit4.XtextRunner$1.evaluate(XtextRunner.java:49)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Re: Default Scope Shadowing [message #1729455 is a reply to message #1716439] Thu, 14 April 2016 05:40 Go to previous message
> class A {
> A m(A a) {
> A a = null;
> return a;
> assertNoErrors
> in the chapter.
> Thanks!
while working on this chapter for the 2nd edition I confirm that with
the default implementation of scope provider the test fails; probably
something has changed in Xtext after the book was written, sorry about
that. Of course, I fixed that in the new edition :)
cheers
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
Xtext Book:
Previous Topic:specify STRING in my DSL, so I can use templates inside the string
Next Topic:Ambiguous binary operator in a PLSQL grammar
Current Time: Sat Nov 08 12:16:57 EST 2025
Powered by FUDForum. Page generated in 0.05410 seconds
